Old 12-12-2018, 12:23 PM   #1
1929
Default Radiator Temperature
Took the car out for its winter exercise yesterday, for over an hour, the radiator temperature gauge was 130 to 135 with the outside temperature about 36 degrees. Is it ok to run the car that cold?, usually in the warm weather its at 160 and above.
1929 is offline   Reply With Quote
Old 12-12-2018, 02:44 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Radiator Temperature
Do you have a t/stat installed?? Concensus is you should.
Paul in CT
Old 12-12-2018, 04:17 PM   #3
Synchro909
Synchro909's Avatar
Ditto instal a T'stat.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 12-12-2018, 04:23 PM   #4
WHN
Model A’s, as we know, were not built or designed for thermostats.
Back in the day they would just block some of the radiator to raise the temperature.
Some owners really like to run a thermostat. That’s OK, it’s their car.
Just keep in mind that for 90 years now. Most Model A’s have been running fine without one.
For 60 years I have not used one. Never a problem, even in up-state New
York.
Old 12-12-2018, 04:39 PM   #5
Synchro909
Synchro909's Avatar
York.
What you are doing is fine but I think the engine will run better and for longer in a cold climate if a T'stat is fitted.
Old 12-12-2018, 04:54 PM   #6
WHN
I’m to old to change, and my car is older than I am.
One of the things I enjoy most about this forum is the interchange of ideas.
Keep up the GOOD WORK!
Bill
Old 12-12-2018, 06:36 PM   #7
30 Closed Cab PU
Here is another recent thread about blocking the radiator, or using a thermostat.
https://www.fordbarn.com/forum/showt...ght=thermostat
When using a thermostat using/providing coolant bypass is recommended to prevent possible cylinder 4 overheating.
Old 12-12-2018, 06:53 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Regardless of how you raise the temperature, with a thermostat or radiator blockage with cardboard, to answer the OP's original question, no you should not run your engine so cold because unburned fuel, acids and water will accumulate in the crankcase that have bypassed the piston rings. You need to raise the engine operating temperature in order to vaporize these bad things and vent them out. Your engine will thank you...
Old 12-12-2018, 06:53 PM   #9
1929
Paul in CT
I removed it because my rebuilder who has a great reputation, and who has been rebuilding these engines for many years, told me I should remove it, so for his experience and knowledge with the Model A, I did as he recommended.
Old 12-12-2018, 07:02 PM   #10
redmodelt
redmodelt's Avatar
160 T'stat or card board or hood blanked or radiator shutters.
