Old 07-02-2018, 03:09 PM   #1
mfarley
mfarley's Avatar
Default Alternator vs. Generator Pulley
I have a 6V alternator on my 29 Tudor Sedan, and I noticed that the alternator pulley is significantly smaller in diameter than a standard Model A generator. The alternator pulley measured 1-1/2" or 1-3/4" diameter and I believe the Model A generator pulley is something like 3 or 3-1/2".
Seems there is always a little more play in the fan belt than should be, and I'm wondering if this is why. Should I account for this diameter difference in belt length, try to put the larger pulley on the alternator, or run it as-is?
mfarley is offline   Reply With Quote
Old 07-02-2018, 03:34 PM   #2
Bob C
Default Re: Alternator vs. Generator Pulley
The alternator needs the smaller pulley. Does the alternator his the lower radiator return pipe??
Bob
Old 07-02-2018, 03:40 PM   #3
Gold Digger
I know the alternator needs a small pulley but I have always had to make a special pulley for all of my alternators. I like a pulley about a half inch larger in diameter so I can make the grove in the center deeper. After about 200 miles the fan belts start running on the bottom of the pulley. Seems the belts are too narrow for the pulleys that come on alternators.
Gold Digger is offline   Reply With Quote
Old 07-02-2018, 04:33 PM   #4
john in illinois
john in illinois's Avatar
You usually need a shorter belt when switching to an alternator. I have never had any problem with the smaller pulley. They supply those so that it will charge at a lower rpm.
John
john in illinois is offline   Reply With Quote
Old 07-02-2018, 05:02 PM   #5
arnhemmer
I switched from an A belt to a modern castellated belt which can handle the smaller alt. pulley much better. The A belts kept on stretching and finally breaking. I got it from Napa auto, just matched up the diameter. It hasn't stretched since I put it on three years ago and clears everything around it do to the belt being slightly thinner. I know it doesn't look like an A belt but a alternator doesn't look like an A generator either.
arnhemmer is offline   Reply With Quote
Old 07-03-2018, 05:39 AM   #6
Jacksonlll
Jacksonlll's Avatar
Run the belt as loose as possible to reduce the side load on the fan attachment to the pump shaft. It's a tapered fit and will wobble if it is not a perfect fit. The way Henry designed it, the load is offset to the rear of the taper joint. Run loose.
Old 07-03-2018, 12:57 PM   #7
SeaSlugs
SeaSlugs's Avatar
also be aware some alternator pullies are installed backwards throwing the belt alignment off. If you look at an alt pulley from the side (perpendicular to shaft)theres a "fat side" and "narrow" side, fat side goes out towards radiator.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
