Old 06-19-2018, 04:01 PM   #1
Gene's Hot Rod Parts
Gene's Hot Rod Parts's Avatar
Default 1932/1933 Ford Pickup Project
City: Knoxville
State: Tennessee
Price: $6,000
Sale Pending on Cab, grill and chassis. Will sell bed for $900
1933 cab, bed and grill and a rolling 32 chassis. These are parts that I gathered to build a Hi-Boy 32 Pickup. My plan was to install a 32 firewall, shorten the bed to fit the 32 chassis and run a 32 car hood and grill. I will sell the cab, bed and a 33 pickup grill separate from the chassis.
This cab is the most solid and straight 32-34 cab I have ever had. It has been stripped and the only rust is the little bit in the lower rear edge. Comes with 32 pickup dash, windshield frame, cowl vent, rear window garnish and a-pillar garnish.
Doors are really nice and solid on the bottoms. They come with original window regulators, latches and door top tins. Also includes new inner door access covers and rear window channel guides. Has all hinges but passenger side lower door.
The bed is a pretty solid 33-34 with a tailgate. Comes with a new rear lower channel. Has some old weld on the driver side fender lip that needs grinding off.
Cab, bed and grill $6,000
The chassis is boxed American Stamping rails with a Deuce Factory tubular x-member with SBC/TH350 mounts. It has a Model style front cross member moved forward 2”. Its about 95% welded and ground.
The front suspension includes Posies Chrome Reverse Eye Spring,
Stainless Steel Spring Perches, Polished Stainless Steel Spindles w/ Polished King Pins, Polished Magnum Stainless Steel Dropped Steering Arms, Zink plated Speedway Shackles, Front Spring Mounting Plate, Drilled 46” I-Beam Axle, Pete and Jake Tie Rod Ends and drag link, Lucky 7 Hairpins and O’Rielly Brake Rotors w/ new bearings, washers and castle nuts.
The rear suspension includes an 8” Ford Rear Axle (2.79 ratio) and
Posies Adjustable Rear Parallel Spring Kit. This will make a great riding chassis. No wheels and tires.
Complete chassis as listed $4,000
Call 865-755-7019
www.geneshotrodparts.com
Gene's Hot Rod Parts is offline   Reply With Quote
