S this B head has a crack through one of the "steam holes" is this fixable? I don't need it right now. I just need to know if I should toss it or save it for some future project or swap meet.
Simon |
That crack needs no fix, unless you want to spend money and possibly end up with some other problem. I would run it as is.
It can be "stitched" up.
If you look close that crack also extends to the combustion chamber which does need to be fixed unless you like water loss and overheating cars :P
#7 | |
![]() Quote:
![]() ![]() When at swap meets it never hurts to have a strip of 500-1000 grit sandpaper in your wallet so upon inspecting you cant tell if its surface rust or a crack a quick little scuff will tell your answer. If the seller doesnt want you to do this they are hiding something. yes its small enough it can be fixed so I wouldn't scrap it.
