Old 05-22-2018, 07:39 AM   #1
imacrazy
Default Radiator Filter
How can I filter sediments from block after flushing, from entering
my newly cleaned radiator.
Bill
imacrazy is offline   Reply With Quote
Old 05-22-2018, 08:01 AM   #2
FRANK PKNY
FRANK PKNY's Avatar
Default Re: Radiator Filter
Flush the block no filter needed. JMHO
FRANK PKNY is offline   Reply With Quote
Old 05-22-2018, 08:17 AM   #3
wrndln
If you use a Gano filter in the upper radiator hose, that will allow you to trap any crud from the block from getting into the radiator. A Gano filter has a see-thru plastic area with 2 screens in it that lets you know when a lot of crud is trapped so you can clean the filter. Gano's website is: http://www.ganofilters.com. I have 2 of the Gano filters and they work great. I sure wouldn't just run the engine without some type for filter to keep the rust, etc from getting into the radiator.
Rusty Nelson
Old 05-22-2018, 09:25 AM   #4
Curtis in MA
Do you have the filter below or above the thermostat?
Curtis in MA is offline   Reply With Quote
Old 05-22-2018, 10:28 AM   #5
denniskliesen
denniskliesen's Avatar
I wouldn't buy the plastic filter, you don't need to see what's in there all the time and it's just 2 more places to leak. Unless You have a lot of debris, remove it once a year and clean it out. If you have a thermostat I'd put it in the upper hose above the thermostat.
denniskliesen is offline   Reply With Quote
Old 05-22-2018, 12:13 PM   #6
ursus
Gano filter? I prefer the more economical Playtex filter, used pantyhose, that is.
Old 05-22-2018, 12:18 PM   #7
Jacksonlll
Jacksonlll's Avatar
Just put an old sock in it for awhile, catch the crud, then toss it. You don’t need a filter in there once the lumps are out. You don’t want you new rad to be a $400 filter.
Old 05-22-2018, 12:24 PM   #8
100IH
Too easy for the rust to slide back down into the engine when the ignition is turned off with the nylon sock method. The Gano is brass mesh built like an Asian fish trap.
100IH is offline   Reply With Quote
