Old 05-08-2018, 10:59 PM   #1
SteveR.
Default Would leaving the ignition on cause damage to the coil?
I don't think so, as it shouldn't be any different than running the car for an extended period as far as the coil is concerned. I left my ignition on overnight (killed my two-week old 6V Optima), and now the car seems harder starting when warm. Spark is orange, not blue. Swapped condensers, no change. Set point gap and filed the points. Just wondering if it is possible to damage the coil by leaving it on for hours.
Thanks for any input!
SteveR. is offline   Reply With Quote
Old 05-08-2018, 11:01 PM   #2
Tinker
Tinker's Avatar
Default Re: Would leaving the ignition on cause damage to the coil?
Yep, it will
Old 05-08-2018, 11:06 PM   #3
SteveR.
Does it burn up the insulation in the coil & cause an internal short? I ordered a new coil...may take this one apart with my daughters after I get the new one.
I normally leave the key in the ignition, will start putting it somewhere else.
Old 05-08-2018, 11:23 PM   #4
GMCPASO
GMCPASO's Avatar
If you have an original pop-out it could burn it out also, Could.
GMCPASO is offline   Reply With Quote
Old 05-09-2018, 12:10 AM   #5
redmodelt
redmodelt's Avatar
Only if the points are closed and current is passing thru them.
Old 05-09-2018, 12:36 AM   #6
J Franklin
J Franklin's Avatar
If you want to open the old one just remember that some used PCB's and that is bad stuff. Better to not include others.
Old 05-09-2018, 06:30 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I've seen a coil burned up in 30 minutes, when the key was left on.
It draws 4 amps with the engine stopped, but only uses 1 to 1 1/2 amps when the engine is running.
Old 05-09-2018, 09:46 AM   #8
SteveR.
Good point, thank you.
Old 05-09-2018, 10:43 AM   #9
Oakhurst
Oakhurst's Avatar
Also with a Petronix it is a big NONO!
Oakhurst is offline   Reply With Quote
Old 05-09-2018, 10:58 AM   #10
abachman3
abachman3's Avatar
As to what to do with your key when not driving, I hang mine on the throttle rod, as it is in the up position and the key ring slides on the nicely. The key is readily accessible from there.
abachman3 is offline   Reply With Quote
Old 05-09-2018, 01:20 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
POCKETS are made for KEYS/CHANGE/SMALL PARTS/ETC.
Bill Cargopants
"THE ASSISTANT GURU OF STUFF"
Old 05-09-2018, 05:37 PM   #12
1929
That's why I like having the cut off switch, its habit forming to shut that, and the fuel every time I park the car.
1929 is offline   Reply With Quote
Old 05-09-2018, 09:47 PM   #13
J Franklin
J Franklin's Avatar
Wink Re: Would leaving the ignition on cause damage to the coil?
Isn't the key a cut-off switch?
Old 05-09-2018, 10:31 PM   #14
cpf240
cpf240's Avatar
Not really, only cuts power to the ignition system.
A true cut-off switch breaks all connection with the battery.
cpf240 is offline   Reply With Quote
Old 05-10-2018, 02:15 PM   #15
Fred K-OR
Fred K-OR's Avatar
A bit off the subject but I had a short in my ignition system and this caused the coil to heat up quickly. So another thing that can mess up a coil. But this is also a way to tell if you have a short (assuming it did not blow a fuse) in your system. If coil is warm, find the short.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-10-2018, 03:49 PM   #16
larrys40
If the points are closed. Sounds like your were. If the points were open ( high point of the cam) you would be lucky.
Agree with Tom. Depending on the health of the coil you can burn it up. It's constant power to the coil which would make it heat up. Like Tom said the constant daw is more than the intermittent of the properly operating ignition circuit.
It probably damaged the points as well. I would install a new set of points, test the coil, ( should be load checked and have at least a 12KV output).
If suspicious try another good known coil. I'm able to test my own coils, condensers, etc so I know what they are doing. Most folks don't have that option and I understand that so that's why I say I would try another known good coil. That one is probably damaged to some extent.
Larry Shepard
Larry
larrys40 is offline   Reply With Quote
Old 05-10-2018, 06:35 PM   #17
Ian in Mississauga
Some of my friends avoid this possibility by hanging the keys on the gas shut-off handle. Also avoids memory lapses with the shut-off.
Ian in Mississauga is offline   Reply With Quote
Old 05-11-2018, 09:04 AM   #18
katy
katy's Avatar
Why tempt fate by leaving the keys in the vehicle?
Old 05-11-2018, 12:16 PM   #19
29Cabriolet
29Cabriolet's Avatar
Agreed! Found this out the hard way. My starter failed when attempting a start and with the key off kept cranking until I grabbed a wrench and disconnected it! Needless to say I installed a kill switch along with the repaired starter.
29Cabriolet is offline   Reply With Quote
Old 05-11-2018, 10:45 PM   #20
SteveR.
I installed a new Petronix coil and the car is running great again. Has a huge blue spark vs. a 1/8” orange spark. Really mad at myself for ruining the old coil...it has “Made In USA” on the bottom. Probably 40 years old or better.
I can pull the coil wire off the distributor and the wire arcs to the distributor near 1/2”, maybe more, and the engine keeps running. Was a good illustration of how it works for my daughters.
I’m going to make this my new habit. It’ll keep me from trying to start before turning the gas on too.
