Question,
how come when you first start a thread you can add photos? but after that the option seems to go away? |
If you reply, and choose “Go advanced” then you should have another chance to add pics.
A lot of times, the photos are too big and the forum won't accept them. It's "hit or miss" thing. I have found the easiest way to make them fit is to load them up in Microsoft "PAINT" (or "PAINT-3D" for you Windows-10 users) and then save them. Make sure you chose ".jpg" as your file type. After I've done that with photos that won't load, I've been able to get 'em in.
Sorry, no help for you "APPLE" types. |
A little tip on photo size, if you use gmail and take pictures with your phone, an smaller version is saved in the cloud in "Photos". The software that runs the Barn is getting pretty old, more modern versions of it automatically "resize" photos.
"whatever works!" |
Posting photos from a phone on this site is a PITA.
I find resizing photos to 35% using PAINT works fine. |
I put 'em in paint and resize to about 800 pixels wide. Normally works and displays well on the screen.
You out and about driving it already? Mart. |
#8 | |
![]() Quote:
If it is desired to reduce the size of photos export them at a lower resolution. Go to the command line and click “File” and then from the drop down menu “Export”. The prompts will explain how to export the photos at full size or less than full size to someplace like the desktop. Charlie Stephens |
I can post pics on the Hamb ,no problem When I try here ,,Same photo ,,it the luck of the draw .most of the times it a no go
That's probably one of the reasons the H.A.M.B. went through the painful process of changing their "Bulletin Board" software a couple of years ago.
I found using a lower resolution on my camera makes the pics upload no problem.
#13 |
Yes Sir went to a thursday night gathering then a Saturday morning.
Here is one pic of the cars & coffee and one from this afternoon. I also put the inner wheel well in on the driver side and also the lower fender braces. and hooked up the led fan switch for the AC. got two estimates on the Exhaust too, right now i have flex pipe with mufflers alot of fumes. Last edited by johnnyford; 05-15-2018 at 11:38 PM. |
#14 |
So my issue was not the res size there was just no options for pics but as told by one of the members go advanced has the ticket!
here ya go! |
#15 |
Nice pics. That's a sweet looking ride you got there.
#16 |
![]() Now I can see your 36 Ford Five window Coupe better. Nice. |
#17 |
Nice!!
#18 |
#19 | |
![]() Quote:
That's easy! DD |
#20 |
thanks for sharing
