Old 05-07-2018, 01:22 PM   #1
oswego37
Default oil weight queston
I recently installed a rebuilt 37 motor in my car. when we fire it up the oil pressure goes up to 20lbs. or so and after it warms up the gauge reads only reads a few lbs. the sending unit is the 50lb one and I used 10w30 oil. seems like 2-3 lbs. is low . Is this normal? Wrong oil? Thanks
oswego37 is offline   Reply With Quote
Old 05-07-2018, 01:38 PM   #2
JSeery
JSeery's Avatar
Default Re: oil weight queston
Your best bet is to install a mechanical oil pressure gauge to double check the pressure (assuming you are taking the current reading on the original gauges). If the pressures are actually that low, it is a bigger concern/issue than adding heavier viscosity oil.
Old 05-07-2018, 02:14 PM   #3
Bursonaw
Bursonaw's Avatar
If you have a remote bypass style oil filter, check to see if you have the .065” oil feed restrictor inline with the filter.
The symptoms you are describing are similar to what they would be without it an oil pressure reducer installed in a bypass filter installation.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 05-07-2018, 06:17 PM   #4
G.M.
Try Castrol 20/50 I think that will fix your problem. G.M.
www.fordcollector.com
Old 05-07-2018, 06:47 PM   #5
Talkwrench
Talkwrench's Avatar
recently rebuilt..?At start up you should be seeing about 60 lbs straight up end of story. as said try a mechanical gauge.. Something is a miss..
Old 05-07-2018, 07:14 PM   #6
drolston
drolston's Avatar
Could be the oil pressure relief in the valve galley is broken or incorrectly installed.
If the mechanical gauge confirms the way-low oil pressure, first eliminate the oil filter flow reducer as the problem by disconnecting the pressure line from the back of the block and plugging it. If you find nothing wrong with the filter or pressure relief, that leaves the oil pump. Ask you re-builder about the pump.
Do not run that engine very long with pressure that low. My tired 59AB with rods knocking and shot main bearings would pull over 30 PSI at speed and almost 10 PSI at idle.
Old 05-07-2018, 09:03 PM   #7
DD931
DD931's Avatar
I agree with GM's recommendation to shift to 20W-50 oil. I've been using it for years and still have great oil pressure. I think 10W-30 is too light.
DD931 is offline   Reply With Quote
Old 05-07-2018, 09:50 PM   #8
Ford Freak
Its been 20W-50 oil for me for years in both my flatty V8's .
Ford Freak is offline   Reply With Quote
Old 05-07-2018, 09:52 PM   #9
Ol' Ron
Ol' Ron's Avatar
10/30 is the proper oil for a rebuilt engine. Adding a heaver oil, doesn't fix the problem. Could be the oil pump
Old 05-07-2018, 10:15 PM   #10
alanwoodieman
take off the intake and check the relief valve, put in a new spring or a washer or just stretch it out==it worked for me
Old 05-08-2018, 08:49 AM   #11
rotorwrench
rotorwrench's Avatar
Rebuilt or overhauled engines should have at least factory recommended clearances on the cam, main, and rod bearings. If not, it won't have good oil pressure from the get go. This is why I overhaul my own engines since I can only kick myself if problems arise. Motor oil does have a tendency to thin some after warm up but the modern oils with expanding polymers should keep a fair viscosity when at operating temperature. A person can expect a 15 psi drop in pressure after complete warm up but it shouldn't be much more than that. If a person wants 45 PSI then cold start pressure should be pegged out on a 50 psi gauge at initial start up with new oil. Always use a mechanical gauge to test a newly overhauled engine. A calibrated one would be best but this isn't the norm unless you are in aviation like I am.
The engine should be test run for relief valve checks and a person has to keep in mind that the intake manifold may have to be removed to do this. If a worn relief valve spring is reinstalled then a new one should be installed if psi is low. If the pressure can not be increased with the relief valve, I would suspect bearing clearance or oil pump gear clearance problems.
Old 05-08-2018, 09:16 AM   #12
DD931
DD931's Avatar
Opinions are like noses. Everybody has one!!!
Old 05-08-2018, 01:39 PM   #13
Ken/Alabama
Ken/Alabama's Avatar
On a rebuilt engine you should see good oil pressure even when it's hot with 30 wt motor oil. Somethings not right. As already mentioned, install mechanical gauge and disconnect oil filter if you have one. If the problem is still there your gonna need to investigate it on the inside.
Old 05-08-2018, 02:31 PM   #14
countrysquire
countrysquire's Avatar
I like the thicker oil because it doesn't spread as far as it drips onto the garage floor...
countrysquire is offline   Reply With Quote
Old 05-08-2018, 02:34 PM   #15
Ford Freak
Yes , or on the driveway ! That is the main reason I use it .
Old 05-08-2018, 02:35 PM   #16
tubman
tubman's Avatar
"2 or 3 lbs" of oil pressure being too low for a rebuilt engine is a fact, not an opinion.
Old 05-08-2018, 04:54 PM   #17
revkev6
My fresh 8ba has 60 going down the road... drops to 15 or 20 hot idle
revkev6 is offline   Reply With Quote
Old 05-08-2018, 05:15 PM   #18
Ford Freak
My 1952 never rebuilt 8BA has 45 going down the road , drops to 5 @ hot idle .
Still runs great ! ( And quiet ! )
However , like the guys above have stated , there is something wrong w/yours if the engine was just redone . Most likely your oil pump is bad . - F F
Old 05-08-2018, 05:27 PM   #19
Ken/Alabama
Or too much clearance in the bearings.
Old 05-08-2018, 06:41 PM   #20
Ol' Ron
Ol' Ron's Avatar
THINK ABOUT WHAT CAUSES OIL PRESSURE?. Resistance to flow. If you've ever seen the oil pump, pump out oil, the flow is fantastic. At idle the flow is about 10 feet, and the pressure is zero. I have a friend with a 284 ci Ardun, has about 10 lbs at idle and 30 in cruise. So far the bottom end is just fine.
