Old 04-22-2018, 05:14 PM   #1
Russ/40
Russ/40's Avatar
Default F100 Brake conversion
As I stumble around the net trying to plan my brake upgrade and trying to figure what pieces i need it occured to me I was reinventing the wheel. It is commonly described as a F100 adaptation. What years of F100 would work. There is the issue of setback, shoe width, bolt pattern, etc. My desire to have a 4.5" bolt pattern is easily dealt with as drums and hubs can be easily redrilled as long as the center hole is 3 1/4" or smaller.
Is there a site that will give dimension date on specific brake drums and backing plates. With that kind of info I could be more auccessful in locating parts in wrecking yards. What years of F100 brakes will work? Clearly 70's vehicles will be easier to find that 50 and 60's pickups. What years will have the backing plate bolt pattern I need, or can be drilled to match. Which F100s are 12". Are some 11 inc"
A good referance site would be great,
Old 04-22-2018, 06:26 PM   #2
19Fordy
19Fordy's Avatar
Default Re: F100 Brake conversion
Russ, Here's some really helpful information.
https://www.hotrodhotline.com/md/htm...arly_fords.php
https://www.jalopyjournal.com/forum/...spindles.5877/
https://www.fordbarn.com/forum/showthread.php?t=24109
https://www.fordbarn.com/forum/showthread.php?t=7549
Old 04-22-2018, 06:45 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Russ....We know that you're aiming for a 5 X 4-1/2" bolt pattern on the rear of a Ford banjo rear end. Surely you have realized by now that the difficult factor in swapping brakes on a banjo is the tapered axle/ hub situation. Nothing else that I have ever seen will directly substitute with that 12" Ford brake drum/ hub. Many folks will agree that the rear LOCKHEED brakes on a Ford are well-able to do their share of the braking required at the rear end, as the fronts do the majority of the "stopping". With that thought in mind, why not just re-drill the 5 X 4-1/2" bolt circle into the ' 40 drums and be done with it at the rear? You can still adapt F100s re-drilled at the front, or any one of the other available options for BENDIX-types on the front. My thoughts are just that the rear hubs/tapered axle situation at the rear make any swap so difficult to engineer. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-22-2018, 10:22 PM   #4
Russ/40
Russ/40's Avatar
You guys have been great. I really appreciate your counsel on what I am trying to do. 19Fordy, thank you for the links as I have read them all. V8COOPMAN, my thoughts have evolved to what you reccomend I do. Handling the rears as you suggest wont preclude doing what i ultimly wanted, if i can find a way down the road.
Thanks for your input guys.
Old 04-22-2018, 10:53 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Hey Russ....You've got a good attitude!
Earlier, you asked about F100 drum diameter. I believe that folks mostly utilize the '53-'56 backing plates when making this swap. Seems like the '57s and later saw some oddball design changes that were not so friendly toward our swapping needs. The '53-'56s were 11" in diameter, but the BENDIX self-energizing action made them superior to the Ford LOCKHEEDS at 12" . DD
T5 W/TORQUE TUBE
Old 04-22-2018, 11:56 PM   #6
mrtexas
mrtexas's Avatar
https://36fordwoodie.weebly.com/f1brakes.html
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 04-23-2018, 04:59 AM   #7
skidmarks
skidmarks's Avatar
48 to 56 f1 or f100 front backing plates are the same
53 to 56 front drum/hub is easier to get a replacement drum.
48 to 52 had a different offset to the hub/drum and drums are more exspensive but a late model bronco rear drum can be made to work
57 and up backing plates will not work.
But the shoes and hardware will work from 48 to the early 60s. You can also change the hardware setup to self adjusting if wanted
skidmarks is offline   Reply With Quote
Old 04-23-2018, 10:30 AM   #8
Russ/40
Russ/40's Avatar
Great stuff guys! mrtexas, wow, that table is just the ticket, thanks. skidmarks, thanks for adding to the mix here. Good stuff guys.
Mrtexas, quick question, am i correct in interpreting the table that the front and rear use the same f1/f100 components less the ebrake of course?
Old 04-23-2018, 11:43 AM   #9
rich b
rich b's Avatar
F-1/F-100 don't fit on the rear without modification.
Front backing plates will bolt-up; but would need E-brake provision added.
The early rear hubs would still be used; albeit with machine work.
Old 04-23-2018, 12:32 PM   #10
19Fordy
19Fordy's Avatar
Russ:
Did you see this? It's been sold but maybe info. is helpful. Or, you can glean more info by PM ing seller.
https://www.fordbarn.com/forum/showthread.php?t=194388
Read here also: https://www.earlyfordv8.org/forum/pr...=17&Topic=3989
Old 04-23-2018, 12:48 PM   #11
JSeery
JSeery's Avatar
The table linked to is one I put together. It was for F1 hubs but most of it also applies to F100 hub conversions. This was for a 33 Ford install.
Old 04-23-2018, 01:31 PM   #12
rich b
rich b's Avatar
Originally Posted by 19Fordy View Post
Russ:
Please feel free to PM me with any questions you may have about this F-1/F-100 stuff.
I have a set of reconditioned F-100 brakes in the classified at this time; but I could easily provide F-1 hubs instead if desired.
Old 04-23-2018, 02:44 PM   #13
mrtexas
mrtexas's Avatar
Not my information. I posted it because I couldn't find it anywhere else. I did sell a set of fronts to be reconditioned to Rich in MN.
Old 04-24-2018, 10:49 AM   #14
42merc
42merc's Avatar
Look at this link--Easy machine work & could be re-drilled to 4 1/2" bolt pattern. I did this a couple of years ago.
https://www.jalopyjournal.com/forum/...#post-12183752
42merc is offline   Reply With Quote
Old 04-24-2018, 01:08 PM   #15
Charlie Stephens
Be sure the wheels you intend to run will fit.
Charlei Stephens
Old 04-24-2018, 02:39 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Charlei Stephens
Just to be accurate, I believe Charlie means that the wheels will fully fit flat, and completely down over the drum. Looks can sometimes be deceiving. DD
T5 W/TORQUE TUBE
