While trying to find an intake leak I decided to remove my manifolds. As I tried to loosen the second nut from the front it snapped. I can see it must have been bent from a previous install. I can tell two of the studs and brass nuts were newer with loctite.
Not the best way to start 2017! I'm not great with a torch so I'm thinking about drilling the center of the stud but don't want to hit to water jacket behind it. Any suggestions? |
I would try Jerry's Broken Drill and Tap Removal, (714) 836-6824.
Charlie Stephens |
Hi 29,
Any friendly Model A owners nearby? Could be as fast as a tooth extraction with an experienced stud remover who could visit to "see" exactly what you have. |
29Phaeton, I have removed a lot of studs on different manifolds IF you have any of the stud still sticking out so you can use a stud remover or vice gripes to get hold of it.
Use a torch and heat just the stud red hot, and then take a spray bottle and spray the stud with water, it will come right out. |
#5 | |
![]() Quote:
'31 180A |
Have an experienced welder tig weld an extension to the broken stud. Then treat with penetrant and try to loosen it.
I got lucky, I was able to drill it and use an easy-out. Thanks to everyone who suggested their own technique. As a newbie it's great to have the community support when needed.
good news!
you were exceedingly fortunate the easy-out did not break
'31 180A |
I agree thanks! I heated up the stud with a torch as I tried to back it out and that worked.
What kind of drill bit did you use?
Using an Easy Out? I thought you would have better chance at winning the
lottery. Glad you got it out though. |
