Old 04-13-2018, 06:45 AM   #1
Dan1928
Default Do Inserts replace Babbitt Bearings?
Do Inserts replace Babbitt Bearings for crank and cam - elsewhere? What would a person need to buy when replacing rods and pistons with new.
Thank you.
Dan1928 is offline   Reply With Quote
Old 04-13-2018, 06:53 AM   #2
George Miller
George Miller's Avatar
Default Re: Do Inserts replace Babbitt Bearings?
You have to do machine work to install them.
George Miller is offline   Reply With Quote
Old 04-13-2018, 07:51 AM   #3
Dan1928
Thank you. So this eliminates babbit? Correct? Just want to be sure.
Old 04-13-2018, 08:14 AM   #4
TerryO
TerryO's Avatar
Yes it eliminates poured babbit...
TerryO is offline   Reply With Quote
Old 04-13-2018, 08:14 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
A lot of inserts have babbitt on them as the bearing surface,
Old 04-13-2018, 08:35 AM   #6
George Miller
Most of the time cam bearings are ok the way they are. There is no bearing material in the cam bearing. They are just bored in the block, so they are part of the block cast iron. If they are worn bad you can bore out the block and put in cam bearings.
