Old 02-08-2024, 04:48 PM   #1
19Fordy
19Fordy's Avatar
Default 1940 Ford
The Green Bible on page 303 shows part # 78-7085- B as the retainer (trans. main shaft bearing) at the rear of the 3 speed transmission used in 1937-40 90 HP cars and also 1939-41 commercial trucks. This is also commonly called the rear transmission mount.
On the same page of the Green Bible is shown part # 21A-7085, retainer (trans. main shaft bearing) used in 1942-48 8 cylinder 90 and 100 HP v-8 cars.
Also called rear trans. mount.
QUESTION: Are parts 78-7085-B and 21A-7085 retainers interchangeable? The center to center measurement of the bolt holes is 8 inches.
They both look like the one shown here except for the center to center distance on mine is 8 in., not 10.
https://www.jalopyjournal.com/forum/...-7085.1205073/
Old 02-08-2024, 07:32 PM   #2
Kube
Kube's Avatar
Default Re: 1940 Ford
They will both bolt up to the rear of the transmission. The 21a part has a shorter center to center distance than the 78 part.
The 21a part will not match your '40 chassis.
Old 02-08-2024, 08:16 PM   #3
19Fordy
19Fordy's Avatar
Kube, Thank you very much for answering my question. I have attached a photo of my OEM 1940 transmission that is still in the car. Do you happen to know what the center-to-center distance is on the 1940 retainer shown in photo of my 40 below?
I took the photo years ago but didn't check the center line to center line of the holes. Thanks, JIM
Old 02-08-2024, 08:34 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Jim ..... The 78-7085 retainer measures 10" between holes on center.
The 21A-7085 measures 8" on center.
The 99A-7085 also measures 8" between holes on center.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 02-08-2024, 09:02 PM   #5
petehoovie
petehoovie's Avatar
Old 02-09-2024, 08:32 AM   #6
Terry,OH
Terry,OH's Avatar
The photo of your transmission does not show the proper rear bearing retainer for the 1940 with an 85 HP engine. When you take it off and clean it you will find the part number embossed into the casting. Below is a photo of the 78- rear bearing retainer note the connection of the ears to the center section and the thickness of the center section. Plus the small ear off the front of the LH mounting bolt loocation.
Didn't we go through this a couple of months ago? Yours being so thick appears like 60HP.
Old 02-09-2024, 09:46 AM   #7
Nick Bernier
Nick Bernier's Avatar
Looks a lot like the bearing retainer on my 1940??
Nick
Nick Bernier is offline   Reply With Quote
Old 02-09-2024, 11:27 AM   #8
19Fordy
19Fordy's Avatar
THANK YOU all very much for delving into my question and providing valuable measuring info. re: hole center line distance. I didn't know about the 8 in. and 10 in. difference.
The current retainer on my 40 was on the OEM transmission (still in the car) when I bought the 40 in 1963.
If I ever need to replace it, I will be sure to check the part #.
Old 02-09-2024, 11:56 AM   #9
petehoovie
petehoovie's Avatar
Old 02-09-2024, 11:56 AM   #10
petehoovie
petehoovie's Avatar
Nick
Old 02-20-2024, 06:10 PM   #11
Bill Schwartz
Hello 40 ford....I too and an 01A guy....Trying to get hold of the TUBMAN
so as to purchase one of his brass connectors for my forty. Have he mailed
him but no luck so far. Does he have an address and/or phone number.
Thanks for any help you can provide.
Bill Schwartz is offline   Reply With Quote
Old 02-21-2024, 02:01 AM   #12
tubman
tubman's Avatar
Bill, I see you have 14 posts, so you can PM me on this forum. Otherwise, my regular email is : "[email protected]".
Old 02-21-2024, 10:28 AM   #13
deuce_roadster
deuce_roadster's Avatar
Bill Schwartz, I am pretty familiar with 40 Fords, where does the brass connector you speak of go?
Old 02-21-2024, 11:07 AM   #14
19Fordy
19Fordy's Avatar
I wonder if he means brass condensers? I too am not aware of a brass connector on a 40.
Old 02-21-2024, 11:34 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
Denny's condensers are things of beauty. Not only that, but they have turned out to be tougher than nails after having sold hundreds to happy users out in the field.
Coop
T5 W/TORQUE TUBE
Old 02-21-2024, 12:29 PM   #16
19Fordy
19Fordy's Avatar
Thanks V8. That answers the brass connector question. Sure is pretty.
Old 02-21-2024, 02:37 PM   #17
tubman
tubman's Avatar
Bill,
I found your email in my "Spam" folder and have replied.
Coop,
Thanks for the compliment. I am actually getting embarrassed.
