I'm not too far away from putting the heads back on my 35 engine and have
the correct torquing sequence but need to know the final number I need to torque them to. Peter |
#2 | |
![]() Quote:
http://www.vanpeltsales.com/FH_web/f...rque-specs.htm
Never more than 50 ft. lbs. no matter which heads.
Thanks guys.
Peter |
Do you have to loosen before retorquing?..... Mark
I read somewhere about “slip tighten”?....you dont get an accurate reading by just tightening.
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP Last edited by flatford8; 03-30-2018 at 11:27 AM. |
I was taught to back off 1/8th turn and retighten through the torque chart 1 at a time. Have never had any problems with head gaskets. I always do at least 3 Hot/cold/re-torque cycles before there isn't any more movement.
I often wondered about backing off the nuts and re-torqueing. Would this not have the potential to also move the stud causing a leak on a fresh engine?
Just a thought..
"Came too close to dying to stop living now!" |
