The car I am working on (Sept. '28) had early '28 wheels for the left hand brake set up. They did not seat against the drums. I now have the correct wheels. The issue is, when I mount the wheel on the brake drum, the axle end pushes the hubcap off. Same later hubcaps, which fit fine before. Drum is where it belongs against the backing plate. Brakes work great, everything is cool, except the hubcaps. What is going on?
Early 28’s had a different hubcap from the later 28/29 hubcaps.
Is this happening on just the fronts or rears? If fronts, there are different front hubs, between early and later production. Hope this helps. Jeff
Let's let pylons, be pylons! Last edited by JDupuis; 03-14-2018 at 09:49 PM. |
Did someone install dust caps, which it originally never had?
No dust caps, and the later '28-29 hubcaps. This is on the back of the car. The fronts are on and fit fine.
Let's let pylons, be pylons! |
I'm thinking of cutting off the end of the axle just past the cotter key. That would gain me about a quarter of an inch. Seems like a crude fix.
You might try A&L as they show an early 1928 hubcap.
Bob |
#9 | |
![]() Quote:
Going git me some of that there packing material...
