Old 01-31-2018, 08:12 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default New parts @#$%^&*!!!
Don't you have it when you buy all the new parts you need to do the job? I decided to upgrade my A to the new design exhaust and while I was at it add a progressive two barrel Holley. New nuts, cupped washers, gasket and exhaust port rings. All went well until I was tightening the nuts. The nut and washer are tight on the exhaust manifold and not even touching the intake. So I guess now my only out is to remove everything and take the high dollar exhaust manifold and have it milled to match the intake. Perhaps bore the nut clearance in the manifold a bit deeper. Wasted time and money caused by poor manufacturing.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2018, 08:43 PM   #2
2manycars
2manycars's Avatar
Default Re: New parts @#$%^&*!!!
As a side note, I just read today that the string of characters you put in your heading are properly called a Grawlix. I try to learn something each day.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 01-31-2018, 09:30 PM   #3
Ernie Vitucci
Ernie Vitucci's Avatar
What was that again? Ernie
Old 01-31-2018, 10:29 PM   #4
RonC
RonC's Avatar
Are you using the new intake? The new intakes are matched to the new exhaust manifolds.
RonC is offline   Reply With Quote
Old 02-01-2018, 01:08 AM   #5
Chris Haynes
It is not a reproduction intake. It is the aluminum one used with the Holley/Weber progressive two barrel.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 01:19 AM   #6
Chris Haynes
grawlix - Wiktionary
https://en.wiktionary.org/wiki/grawlix
grawlix (plural grawlixes or grawlix) A spiral-shaped graphic used to indicate swearing in comic strips. A string of typographical symbols, especially "@#$%&!", used (especially in comic strips) to represent an obscenity or swearword
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 01:45 AM   #7
Lawrie
Lawrie's Avatar
What i did was cut a piece of a washer that matched the difference in the flange thickness,cut it in half and weld or braze or tig it to the main flat washer,problem fixed.
lawrie
Old 02-01-2018, 02:06 AM   #8
Rex_A_Lott
Maybe the picture doesn't do it justice, but it looks like it's touching to me, just a little bit, at the very corner of the washer.
That was the idea of the conical washer, so it could cock and take care of that misalignment.
I believe you could spend a few minutes with a die grinder and a burr and be good to go. Good luck!
Rex_A_Lott is offline   Reply With Quote
Old 02-01-2018, 07:47 AM   #9
George Miller
George Miller's Avatar
I think the idea is when you buy new parts they should fit. who ever made them knows they are wrong. They should correct the problem.
George Miller is offline   Reply With Quote
Old 02-01-2018, 09:13 AM   #10
old31
Well who would have thunk that that would actually have a name.
old31 is offline   Reply With Quote
Old 02-01-2018, 09:36 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
I had a ex manifold that was cut too much, I took washers and cut them in 1/2 to use as spacers under the thick washer ---I don't believe in cutting both together ---i only tighten the 2 bolts enough to compress the lockwasher after the manifold to block nuts are tightened ====the last manifold had a lot of space, thhe car loked real hot weather better that way
Old 02-01-2018, 11:01 AM   #12
Scottio57
Scottio57's Avatar
Or maybe grind down the thicker manifold to match the exhaust.
Scottio57 is offline   Reply With Quote
Old 02-01-2018, 11:36 AM   #13
denis4x4
denis4x4's Avatar
I suspect that the manifold manufacturers assume you will be using headers. I have two versions of that intake on my cars and made aluminum C clips to secure the intake when using headers. I also use a grinder to make sure the "ears" are flat. This particular photo shows a Stromberg-Bendix intake.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-01-2018, 01:57 PM   #14
Beater
Beater's Avatar
denis whose header is that?
Beater is offline   Reply With Quote
Old 02-01-2018, 05:12 PM   #15
denis4x4
denis4x4's Avatar
I suspect that it's a Red's as I bought it from Bert's in Denver
Old 02-02-2018, 01:26 PM   #16
Beater
Beater's Avatar
Thankyou
