Old 01-29-2018, 02:38 PM   #1
flathead 53
Default power brakes 65 comet
I am changing to manual disc brakes on my comet.My question is will I need an adapter on the fire wall to install the dual master brake cyl ? or will the master cyl just bolt in place of the power booster? thank you.
flathead 53 is offline   Reply With Quote
Old 01-29-2018, 04:47 PM   #2
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Default Re: power brakes 65 comet
You shouldn't need an adapter. A dual well '67 Mustang master bolts right in place on a '65/'66 Mustang. Can't see a Comet being much different. Make sure you get a manual disc/drum master from a similar size/weight car for your update, like Mustang /Cougar.
streetdreams is offline   Reply With Quote
Old 01-29-2018, 06:57 PM   #3
V8 Bob
V8 Bob's Avatar
The pedal ratio should be checked. Normal power ratios are around 3:1, while manual are +/- 6:1.
Old 01-30-2018, 04:33 PM   #4
flathead 53
thank you all for the info. wayne
