Old 12-21-2010, 01:27 PM   #1
Doug in NJ
Doug in NJ's Avatar
Default Garnet as blasting media?
Hello,
I was in Tractor Supply yesterday and I noticed that they had 80-grit Garnet media for only $25. How would garnet compare to glass beads in a blast cabinet? I have been using glass beads, but they are a bit wimpy for rusted stuff.
Thanks and Merry Christmas to all,
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 12-21-2010, 01:47 PM   #2
pooch
pooch's Avatar
Default Re: Garnet as blasting media?
Quite OK for rusted parts.
Just test when you are doing external sheet metal for "profile" finish.
http://www.launcestonsandblasting.co...ile/index.html
pooch is offline   Reply With Quote
Old 12-21-2010, 04:32 PM   #3
AJ
AJ's Avatar
I looked it up, and according to this website's chart (link below), it may be a little better at rust removal then glass bead. It's harder then beads, but doesn't last as long.
http://www.nortonsandblasting.com/nsbabrasives.html
AJ Elias
The Hot Rod Disorder
AJ is offline   Reply With Quote
Old 12-22-2010, 09:07 AM   #4
al pa.
My harbor freight benchtop cabinet wouldn't feed abrasive larger than glass bead,and I had to add a different gun,to help prevent clogging.
al pa. is offline   Reply With Quote
Old 12-22-2010, 05:51 PM   #5
pooch
pooch's Avatar
If you have the steel pickup tube that you dunk in the media, no wonder.
Modify the cabinet if you want any success.
