Old 03-21-2017, 05:42 PM   #1
gypsycandle
gypsycandle's Avatar
Default Question on the safety switch?
If the safety switch is installed so that the case of the switch touches the frame, does that create a ground and nullify the purpose of the switch?? I know it is a switch in the positive side (which is ground in the Mod A) but if it touches a ground , what happens electrically? Thanks in advance.
gypsycandle is offline   Reply With Quote
Old 03-21-2017, 05:45 PM   #2
A31Woody
A31Woody's Avatar
Default Re: Question on the safety switch?
I don't know which one you're using, but the outside should be insulated. As long as the poles don't touch... you should be fine.
A31Woody is offline   Reply With Quote
Old 01-24-2018, 12:23 PM   #3
3.6rs
3.6rs's Avatar
If you want to cut off the positive ( model A ground) and this touches the ground (so, the positive) there will be NO cut off. As simple as that.
But why installing a cut off switch that is n,ot isulated ? That is the question...
3.6rs is offline   Reply With Quote
