I heard that there is a re-enforced bell housing (forward), but I don't know how to identify it. I have spent the day cleaning up bell housings and found all three cracked. What do I look for to tell if they are cracked before I spent so much time in sandblasting. I have cracks in three different places, so I guess any place is subject to cracking. Is there any fix to these or are they just scrap? Also how do i tell if it is a re-enforced housing? When were the re-enforced units used? Thanks for the help.
Flywheel housing 1931 has extra ribs on the outside bottom 1/2 can't miss it.
Here's some pictures.
Bob |
Midget,
Learn the "ring" of a good one, when tapped with a hammer. A crack, anywhere, will make one go "THUD"---Sorta' like the Liberty Bell--LOL Bill Musicaldingdong
#5 | |
![]() Quote:
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
What will happen if you drill a "stop hole" at the end of a crack and then stitch it? I did that to a couple with small cracks and they seemed strong enough, yet no ringydingy when tapped with a hammer, just a dull thud. I tried to displace the metal at the open end of the crack repair and could detect no movement though I put a very good pull on it with a large crescent wrench. Will they hold? should I try welding over the stitch? If so, cast iron rod or what? Brass? The venders sell new re-enforce one's, that's one option$$$
The problem with the 'bell ring' method is it only works if its off the car. Removing the housing is a pretty severe step just to do an inspection.
#9 | |
![]() Quote:
Here is pictures of cracks from four bell housings. Some did not show up until I had primed the bell housing. I had one other that was cracked in similar place to the fourth one. I am running out of candidates. The problem with the ring teat is that you must clean all the grime off before it will work. Picture 3 bell housing will ring, but the small crack has me worried that it will grow with time. I appreciate all ideas. I found out I have no re-enforced bell housings.
I have marked the crack area with marker to make them easier to see. pic1 has a crack right up next to the engine mounting flange
I have marked the cracks with marker. Pic 1 has a crack next to the engine mounting across from the starter.
#13 |
Took me five flywheel housing before I found a good one..three early's, a late reinforced and an aftermarket one no one can identify(Ill post up a picture tomorrow) one of the early ones had the cracks pinned and it ran out at.003... I was going to run it till I found a late reinforced one,uncracked that dialed at .002..the only way to crack check them is to bead blast them..good luck,its critical to smooth shifts and vibration reduction.
![]() B flywheel checked at .001,balanced with clutch. |
#14 |
Man, I didn't realize the bell housings were so prone to cracking. No wonder there are so many for sale. I think I liked this issue better when I was ignorant of it
#15 |
Torch welding with cast iron rod is easy, if it's CLEAN & you have the proper flux. I "think" my years at hard facing plow shares, was a big help in my technique.
I've had success, using Nickel-Arc. Weld a short distance & peen it, often. I have NEVER welded a bell housing, though. I "wonder" about warping or distortion?????? As a sidenote: I've NEVER torch welded Alujimum, I'd love to learn to do it. In the '50s, as a welders' helper, I learned to weld Alujimum, with a New Fangled Heli-Arc Machine. It was a BIG project & we got "pretty" GOOD--LOL Bill Sparkingandflaming
#16 | |
![]() Quote:
![]() ![]() ![]() ![]() Bill Paranoid
#17 |
Most flywheel housings (not bell housings they are the bit with the pedals on !!!) you find at swap meets are cracked, that is why they are there .Housings get cracked when someone jacks the front of the engine up to work on the pulley or front motor mount without removing a bolt each side from the rear motor mount so the motor can pivot .
John in cold wind snow and gales on the way spawned in the Great Lakes Suffolk County England . |
#18 |
The part that is prone to cracking is the Flywheel housing, Not the bellhousing. the bellhousing is between the flywheel housing and the transmission, and is shaped roughly like a bell.
#19 |
In looking at your pictures make sure 1,2 and 3 are cracked through and not just casting flaws,picture 4 is the classic crack.Can anyone identify this one?
#20 |
![]() ![]() classic cracks from the lower support bolt holes..general vehicle operation causes it in my opinion,its a design flaw.The bell housing load is equal all around,the flywheel housing is only supported on the upper half by the block. The repaired one I have they just pinned the cracks,no weld...have another one weld repaired from bottom damage repair..that one was all over the dial,deviation of .020,reckon the weld heat had something to do with it. |
