Old 01-13-2018, 12:17 PM   #1
BillCNC
BillCNC's Avatar
Default Youngest Person to Rebuild a Transmission?
Hey All,
My son and I were curious as to who the youngest person is to rebuild a Model A Transmission?
Well, we would like to toss my Grandsons hat in the ring, ... He just turned (6), YES, ... SIX Years old and in Kindergarten.
We made a video of the build and my son is going to get it ready to toss up on Youtube. With any luck, ... he to might own a Model A one day....
Here are a couple of pictures of the trans dirty to show a parts count and then the finished up trans. I figure it will be something to brag about for years, ... A SIX year old built my transmission.
Parts Replaced;
A - 7113 Cluster Gear
A - 7111 Gear Cluster Shaft with O-ring
A - 7140 Reverse Idler Shaft with O-ring
A - 7025 Bearing
A - 7065 Bearing
A - 7045-B Snap Ring
A - 7060 Main Shaft
A - 7061 Main Shaft Collar
A - 7063 Spacer
A - 7118 Needle Bearings (short) x2
A - 7121 Needle Bearing (long)
A - 7111-2 Transmission Seal Kit
A - 7153 Transmission Gasket Set
*** Now for the RANT:
All the parts seemed to fit well with the exception of the main shaft, ... the diameter was to fat for the (old) slider gears to even fit on. I had to bring it down .002" in diameter and break the edges on all the splines and front leading edges, ... NO final inspection, NO De-burring of the part!
YUP, ANOTHER Piece of Crap, ... USA made part causing yet another 30 minutes to make a *** NEW *** part CORRECT!
Is it just me or does anyone else find it absolutely mind boggling that these parts were made correctly in the 1928 - 1931 on VERY CRUDE machines, yet, ... With the top of the line CNC's we cannot make the simplest parts correctly, ... even in the USA?
I also added a picture of the packaging for the Main Shaft that I had to rework. If anyone can decipher the codding on the label, ... AVOID at all cost unless you know how to machine and rework metal.
Regards
Bill
BillCNC is offline   Reply With Quote
