Go Back   The Ford Barn > The Swap Meet > For Sale > Model-T
Old 11-19-2017, 02:22 PM   #1
petew
petew's Avatar
Default 1927 T Roadster Powered By A Modified Model A Engine
City: Mebane
State: NC
Price: $24,500
For sale is my original steel 1927 T Roadster . It is powered by a modified 1929 Model A engine.
*Original 1927 T body finished in Washington Blue.
*Custom built frame
*1929 Model A engine with pressurized oiling , insert bearings, counterbalanced crank, fully balanced rotating assembly, aftermarket rods, Stipe B cam, aluminum Winfield cylinder head, V8 oil pump ,dual 9 Super 7 carbs (stromberg reproductions), lightened flywheel , V8 clutch , FSI electronic distributor, external oil filter , oil cooler ,thermostat, alternator , tube header, Griffin aluminum radiator, V8 water pump.
*Engine built by James Rogers of Dream Works .
*5 speed manual transmission
*Model A banjo rear with 3.54 gears.
*Front disc brakes.
*Rear 1946 drum brakes.
*Dual master cylinder.
*Kelsey Hayes wire wheels.
*Leather interior with a custom made seat , plenty of room for me @ 6ft 200lbs.
*Original but modified Model A brake and clutch pedal assembly.
*Tonneau cover , with center zipper.
A nice car that is a pleasure to drive , with overdrive in 5th gear and the 3.54 rear it will run 70mph @ 2000 rpm’s .
Send a PM if you are interested or email me at [email protected]
petew is offline   Reply With Quote
Old 11-19-2017, 02:25 PM   #2
petew
petew's Avatar
Default Re: 1927 T Roadster Powered By A Modified Model A Engine
Some pictures.
File Type: jpg 11F94CE0-C5CF-452A-BD35-2CAEF7235668.jpg (102.4 KB, 126 views)
File Type: jpg 17EED447-D1DB-47C3-82A2-CEB156F372F4.jpg (35.5 KB, 85 views)
File Type: jpg 77EC41ED-89B5-4F07-8199-A96EB564F1A2.jpg (56.1 KB, 102 views)
Old 11-19-2017, 02:29 PM   #3
petew
petew's Avatar
A few more
