I read on this forum that if a rattle paint can stopped working you can spray WD-40 into the can and it will continue to work until empty. What is the relationship between WD-40 and paint. If I have WD-40 on a part and then paint it will the paint stick to the surface or is there a problem with doing this?
The same question is with the evapo-rust, will it interfere with the paint after an evapo-rust treatment or is it OK to paint over a treated part? Jack |
WD-40 is a type of oil and would need to be cleaned thoroughly before being painted over. Evaporated-Rust will leave a residue and will also need to be cleaned.
I have enough problems when I paint, I don't need to add oil to the process.
IMHO WD40 is good for starting fires and little else.
And glass shower doors and little else.
I Love Anything That Turns Money Into Noise |
The straw on the can of WD40 fits into the bottom of the paint can nozzle to clean the nozzle out and it should not to be put into the can.
Instead, I have also used my air compressor with a rubber tip nozzle to add pressure to a flat aerosol can with some success. Take off the nozzle and point tip into can. It doesn't take much psi's to get it to work again to get out the last of the contents... |
I squirted WD40 on a very noisy fan belt the other day. Instantly quiet! I'm gonna try Dave's idea (right above this) on a spray can of PB Blaster that gave up the ghost with a lot left in the can.
WD- 40 is a silicone lube. Do Not use around paint. Just Sayin. Used to be a body shop manager and it was not allowed in the shop. Nor was Armor All, etc., all the silicone products do not work well in a body shop, i.e. paint area.
Brian |
I soak the nozzle in acetone for a day or so and it clears the hole.
Dick |
And potato guns. Also removes that stuck on gunk in your finger prints.
We nicknamed a guy at work, silver duck, he was trying to get silver paint out of a can he thought was dead.
The very best hand cleaner is KFC original recipe!
#13 | |
![]() Quote:
