My brother needs a good picture of the put together process of the tilt steering and assembly inside the upper steering column on his 87 Ford truck. We have the tilt lever with the 4-5-6 grooves mounted finally installed after we flipped it over correctly and got the spring in also. He has 3 screws that go in some hard plastic rectangular pieces that he believes installs from the bottom. Like between near the actual dash and bottom of the column. Anyone hear help? With pictures or links? Thanks
