Old 08-15-2017, 11:38 AM   #1
chopnchaneled
Default king Pin Bushing Reamer
Anyone here had any experience with the one from Brattons ford parts ?
Thanks for any input.
chopnchaneled is offline   Reply With Quote
Old 08-15-2017, 11:59 AM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: king Pin Bushing Reamer
When you do the job with any reamer, dont ever turn it counterclockwise. That would ruin it fast.
Old 08-15-2017, 12:14 PM   #3
briphaeton
Having the king pin bushings honed is the best way.
briphaeton is offline   Reply With Quote
Old 08-15-2017, 12:29 PM   #4
kenparker
kenparker's Avatar
Yes, I have one of the Brattons King Pin Reamers. Had it 'bout ten years and have used it probably dozen times. Good tool. As Jackson said, never turn it backwards - that will dull it immediately. ken
kenparker is offline   Reply With Quote
Old 08-15-2017, 02:54 PM   #5
chopnchaneled
Thanks for the input, I "had" a keystone reamer for many years, until the other day,
I managed to drop it and of course it shattered.
The bratton one looks like i would be able to stay in alignment with both bushings.
Old 08-16-2017, 05:22 AM   #6
harleytoprock
My local machine shop honed my king pin bushings for a perfect fit and finish for $35. The end result is better than any reamer can do.They were line honed on a Sunnen honing machine. It doesn't pay to buy a reamer.
harleytoprock is offline   Reply With Quote
Old 08-16-2017, 06:24 AM   #7
aermotor
Same here but $40.
John
aermotor is offline   Reply With Quote
Old 08-16-2017, 07:55 AM   #8
2manycars
2manycars's Avatar
Honeing is the best, but I have had good results with a reamer if carefully used. Mine is at least 50 years old, but I have only used it less than 10 times in 50 years.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-16-2017, 07:58 AM   #9
wrndln
A reamer works just fine. I've done it on 3 front ends. Honing works also. I don't think it make much difference which way you do it. I think some people over think this operation.
Rusty Nelson
Old 08-16-2017, 08:14 PM   #10
Kevin in NJ
Honing is the perfered method. Done right it will give a round hole the proper diameter.
A reamer will always leave a little high spots which will wear fast. So it will be tight and rapidly loose a small amount until it is round and a bit loose.
Again you are better off with honing. Careful reaming with a good tool will do the job too, just know the difference.
Old 08-17-2017, 03:38 PM   #11
Will N
Will N's Avatar
The idea of a reamer is that it does the top and bottom bushing at the same time, ensuring they are concentric. Yes, the reamer leaves high spots. But I've been told that you should leave it real tight after reaming, and spin the kingpin in place to burnish the bushings and get a nice fit. I dunno...
Will N is offline   Reply With Quote
Old 08-17-2017, 06:03 PM   #12
Synchro909
Synchro909's Avatar
Burnishing the bearing surface is what I do. If the bush is left too tight, the car will be all over the road and VERY scary. Burnishing leaves a round hole. The same can't be said for honing. A hone only follows what is there. Hone an oval hole, it will end up oval. I NEVER hone king pin bushes.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 08-18-2017, 07:36 AM   #13
chopnchaneled
UPDATE !!!!!!
Received my new reamer from Brattons, Put it right to work and the bushings came out great.
The only thing that would make it better is having a guide down to the second bushing
to help get the cut started straight" it has under sized cutters on the first stage", other than that it worked just as well as my Keystone reamer that i dropped and killed.
