Old 08-13-2017, 10:19 AM   #1
wingski
wingski's Avatar
Default loose steering
I've got '29 up on jack stands and noticed that there is a lot of play in the steering. I can turn those front wheels back and forth at least 4" before the steering wheel budges. Suggestions? Another thing, both of my shoulders are really fouled up, and I'm afraid that I'm going to have trouble steering the A. It's got a beautiful brand new steering wheel and I hate to mess it up by putting a spinner (squirrel knob) on it, but I don't think I have an option. Again, suggestions?
wingski is offline   Reply With Quote
Old 08-13-2017, 10:33 AM   #2
Bob C
Default Re: loose steering
Get an F100 steering gear conversion from Randy Gross.
https://www.fordbarn.com/forum/showthread.php?t=224905
Bob
Old 08-13-2017, 10:47 AM   #3
wingski
wingski's Avatar
That's good advice, Bob, but since I've got the thing up in the air isn't there something I can do now?
Old 08-13-2017, 10:47 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
FIRST, figure out WHERE the SLACK is.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-13-2017, 10:53 AM   #5
SSsssteamer
SSsssteamer's Avatar
On my '29 Tudor, I had the same problem. I rebuilt a two tooth steering box and installed it in place of the worn out one. I also took out all of the lost motion in the tie rod ends and drag link. My kingpins were OK. Problem is completely fixed and it steers easily and everything is proper as Henry built it. The two tooth steering box has a couple of adjustments that make up for a bit of wear. The 1928 and early '29 seven tooth steering box lacks these adjustments for wear. Replacement parts for the two tooth steering box are easily available. After driving the Tudor for a couple hundred miles with its rebuilt steering box, I had to readjust the steering box while it was still in the car. Right spot on.
SSsssteamer is offline   Reply With Quote
Old 08-13-2017, 12:51 PM   #6
Patrick L.
Patrick L.'s Avatar
What Bill said.
Something is loose. Find everything thats loose and fix it. That means everything between the wheel bearings back thru to the steering box adjustments.
Old 08-13-2017, 09:32 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Have your wife move the steering wheel back and forth for the 4" while you look underneath for the lost motion. Sometimes it's just a loose pitman arm bolt, or loose wheel bearings. The pitman arm bolt need to be very tight, while the wheel bearing just need to have very light tightening, like the weight of a 10" adjustable wrench on the nut at the 3 o'clock position.
Old 08-13-2017, 10:48 PM   #8
BILL WILLIAMSON
Is that a HEAVY DUTY or a LIGHT DUTY wrench?---UR a Monkey Wrench?
Bill Lightduty
Old 08-14-2017, 01:27 PM   #9
wingski
wingski's Avatar
Tom, I love it when someone tells me what to, and how to do in terms I understand. I retired as a technical writer for heavy machinery and some of the manuals I had to rewrite were not only confusing, they were dangerous. I made sure that the manuals I wrote were understandable by the people reading them, and that they didn't stop in the middle of how to do a job and refer you to page whatever. Thanks again.
Old 08-14-2017, 02:26 PM   #10
jwilliams81
jwilliams81's Avatar
I just did this while the front end was up on stands...
http://modelaclub.com/archives/tech-tips/981
I got it down to 3/4" of free play in the wheel.
I would second a vote on the pitman arm bolt.
As well as the two bolts that hold it to the frame.
I actually cranked on those three with a 1' cheater bar.. that has really helped too.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 08-14-2017, 03:55 PM   #11
jrelliott
jrelliott's Avatar
Why not check everything right now: Kingpin fit, balls on front spindles where tie rods and pitman linkage connect, tie rod cups, tension on the tie rod cups, pitman arm ball, pitman arm bolt tightness, steering box bolts tightness, steering box etc. While you don't have it all assembled now is the time to check things. A real pain after everything is put together. Good Luck
Old 08-14-2017, 07:50 PM   #12
jm29henry
jm29henry's Avatar
Fix what is worn but leave it original just my thought
jm29henry is offline   Reply With Quote
