Hi, is it a big difference between Zenith and Tillotson carburetor at the ride / setting? My car may need a replacement carburetor. On Ebay, the Tillotson are noticeably cheaper than Zenith offered. It even reads that Tillotson should be better.
How are the practical experiences please? Very thanks in advance!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
This has been covered many times and many have varying opinions on them. Some people don't like Zeniths, and others only run Zeniths and think that the others are junk. Do your homework and decode what you think is best for your car and engine.
https://www.fordbarn.com/forum/showt...ight=Tillotson
"The more things change, the more they stay the same." |
Don't be afraid to look into the Marvel's. I have all three and for cruising I prefer the Marvel. It seems to have more zip and the mileage is good. Jack
This is purely an assumption on my part. I believe the Tillotson or Marvel probably are better designed carburetors because they proceeded the Zenith, making improvements to correct prior deficiencies. Having said that if you are a purist nothing but the Zenith will do.....
All 3 are good carburetors when set up correctly. Why not just clean and set up your Zenith ? As far as your question though, the Tillotson likes more fuel/GAV
The idling air nozzle is 3/4 open, the GAV <1/8 open. For 100 km I use 20 liters. That's 12-13 miles per gallon. Ignition perfect with stroboscope, new spark plugs iridium, compression 4 bar, oil consumption 1/2 quart / 500 ml. Without airfilter, the car runs a little faster (unimportant) but even more rough. Therefore, I would like to stop experimenting and replacing nozzles, but perhaps try a complete different carburetor.
I have run both Tilly and Zenith carbs.,putting 1000's of miles on each from climbing mountains to 4 lane highways. And to date a Zenith carb. restored with Renner's Corner flow tested jets is the best one of all.
Just got back about an hour ago for a 3 day 331 mile trip in the Pa mountains and the car ran flawlessly with the Zenith carb. I have a 30 Tudor and got 21 miles per gallon. |
I am assuming that your engine is like our engines and not like the British engines. But 12 or so mpg is really low. My zenith on my rebuild let’s me cruise between 50-55 and I am guessing I get around 20 mpg. I am running Renners jets inside and they is all- no air filter as that will cause your mileage to go down. However, I love my Marvel for its power and mpg.
Mike
I decided to experiment to see which carburetor would give the best economy and performance . Over the years I have collected many . The Marvel ran OK about the same as the Zenith but with a Tillotson it runs the best .More power and better gas mileage . I tried 4 different Zenith and several Tillotsons . All these were clean and correct float height . It just seems my P/U loves Tilly best !!! . At swap meets Tillotsons are plentifull and very cheap normally in the $5 $10 nobody seems to want them but I think they are a very good unit certainly equal if not better than the Zenith . One good point is that they do not stall out on heavy braking as the Zenith sometimes does . On idle they they are not as smooth and wont "tick off" like a Zenith can but that does not bother me .
John in a hot summers evening Suffolk County England . |
No, as for price most want what Ford used so demand is higher.
The saying is: Zenith for the show car Tilly for the Go car. That being said, I've got a Zenith on mine, just because thats what was on it when I got it and its never needed anything as far as service, runs great. I have a Marvel cleaned and rebuilt to put on if I ever need it. Tilly sitting around too somewhere.
I have run all three carbs. The Zenith is a good carb and runs well. I have it under my seat as a backup carb. However, I now have a Marvel Shembeler on my A. I like it the best. I think it gives you more power at higher speeds. They only thing I would say that is critical of the Marvel is you can never give it any throttle when starting either a cold or hot engine. I found that if you just pull the choke and immediately drop it it will always start. Other wise, you can flood the engine.
If you are interested in a Marvel, there is a fellow in Texarkana, TX that does nothing but sell rebuilt Marvels. He rebuilds them and is the Marvel guru. His name is JR Bullock and his telephone number is 903-748-8229. He charges a flat $200 and ships free in the US. He is also listed on Ebay. Viel Gluckness!! = (Good Luck) |
#13 |
I second JR Bullock.He also rebuilds tillys.A real nice guy
#14 |
Does anyone have any experience with the Simmons carb?
How does it compare? Does anyone rebuild them? I have one, somewhere, but have never run it. |
#15 |
Marvel, Tillotson, and Zenith all seem to be good carburetors from my experiences with them. It's really hard to say which is best.
I remember getting good gas mileage from my Tillotsons. A little more power with the Marvels. But, I'll give the edge to Zenith for overall smooth performance. |
#16 |
Anyone got a s,/h Tilly? I only need the top for my XF as the inlet thread is striipped, I'm in the UK
#17 |
Do they sell Helicoil inserts in the UK?
#18 |
#19 | |
![]() Quote:
#20 |
