Old 07-04-2017, 11:40 AM   #1
DennisR
DennisR's Avatar
Default Fitting a V8 in an A
Briefly, if possible, what is involved in fitting a flathead in a 1930 coupe?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe
DennisR is offline   Reply With Quote
Old 07-04-2017, 12:02 PM   #2
flatford39
Default Re: Fitting a V8 in an A
59's are a lot easier than 8BA's (ask me how I know) but you are going to have to make your own motor mounts for the front (pretty easy) and I used a transmission cross member from an F-1 pick up to support the transmission and then if you use a 37 39 transmission with it and the 37 39 rear end you have some fitment details there that are going to require welding skills. I don't recommend the A rear axle. You will be constantly shearing the axle keys. Then you need to modify your radiator re wire, hydraulic brakes etc etc. Get Vern Tardells book on the subject. it shows you step by step although there are some mistakes in it.
I am in the process of doing it and it is a big project in my mind. It is not a bolt in. Would I do it again. Absolutely.
flatford39 is offline   Reply With Quote
Old 07-04-2017, 12:47 PM   #3
48fordnut
48fordnut's Avatar
Good advice from39. The book is good, but lots of mistakes. Look on the HAMB and there are many pics and advice.
48fordnut is offline   Reply With Quote
Old 07-04-2017, 12:53 PM   #4
DennisR
DennisR's Avatar
Appreciate you taking the time to reply, been refurbing my coupe and keep getting ?`s on why don`t you fit a V8, it`s easy, just drops in etc., TBH I didn`t have a clue, wasn`t that interested I like it as it is, now I can answer them with confidence.
Having said that I wouldn`t mind a little deuce coupe but over they are quite rare in standard form they`ve all been "got at"
Thanks again, Dennis
Old 07-04-2017, 12:56 PM   #5
Charlie Stephens
Tell them you like it like it is and it would cost $XXX just to rebuild the flathead before you installed it.
Charlie Stephens
Old 07-04-2017, 05:21 PM   #6
TonyM
TonyM's Avatar
Souping up a 4 Banger is another time-honored tradition. Lots of stuff available.
TonyM is offline   Reply With Quote
Old 07-04-2017, 09:53 PM   #7
40 Deluxe
"constantly shearing axle keys"?? First, I think the axle keys in a V8 axle are the same as an A axle. More important, if you just torque the axle nuts properly you will never shear a key. Twist or break an axle, yeah, but you could throw the keys away and keep going if the axle nuts are tight like they should be.
Old 07-05-2017, 12:17 AM   #8
Paul Bennett
Why not sell the old girl and buy a 32 or 33? Unless you need a project I cringe whenever I hear of a decent car being cut up and re-engineered. If you insist, put in an LS2 or LS3 for about the same money as a FH.
Paul Bennett is offline   Reply With Quote
Old 07-05-2017, 11:51 AM   #9
Bill Batson
I used Mike Bishop and Vern Tardel's book as a guide in building my 29 AV8. I did use a 1951 8BA and got it to fit but agree a 59 series block would be easier. Made up a 39 trans from about five donor trans and used a 40 rear end. Followed the book's advice on how to get it all working with a little fabrication of my own.
Its a ton of fun and steps right out.
Bill
Bill Batson is offline   Reply With Quote
Old 07-05-2017, 11:58 AM   #10
flatford8
flatford8's Avatar
I cringe when I see/hear of a LS motor going in an old Ford. I would think alot less "re-engineering" to put a FHV8 in it. I like the idea of souping up the banger...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-05-2017, 05:09 PM   #11
pooch
pooch's Avatar
Bill
Yep, heaps of fun....21 studder, 39 toploader, 16 inch wires, running cowl tank, 39 steering wheel, engineered to seat 4 with retractable belts all round.
pooch is offline   Reply With Quote
Old 07-10-2017, 06:40 PM   #12
mountstimothy0
I appreciate your topic on this. I'm doing the same thing to mine I have a frame 2 Flathead. And a trans and rear end from a 39. Ya some people frown on what we do on this sight but I think they forget that's how they hot rodded cars in the 50s so to me and my dad it's still nostalgic
Sent from my SAMSUNG-SM-J120A using Tapatalk
mountstimothy0 is offline   Reply With Quote
Old 07-11-2017, 09:24 AM   #13
Ed Pitts
Ed Pitts's Avatar
A work in progress for my 28 Coupe.
Ed Pitts is offline   Reply With Quote
Old 07-11-2017, 03:26 PM   #14
supereal
supereal's Avatar
I put a V8 in my Model A two door when I was in high school in the late 40's. I found several problems with the switch. The brakes were dangerously inadequate, the steering was sloppy, just to name a couple. It was interesting that breaking a rear axle wasn't rare, as we found out with careless driving. I never broke an axle after the swap. I suspect the difference was caused by the difference in fly wheels. The original "A" was a heavy piece, compared with the V8 type, increasing the low speed torque at low speed takeoff.
supereal is offline   Reply With Quote
