Old 06-09-2017, 02:40 PM   #1
Ball and Chain
Ball and Chain's Avatar
Default Proper size reamer early ford steering wheel?
Does anybody know where to buy the proper size (3/4 x ?) reamer for an early ford wheel 35-48? I know its kinda hot rod to put another wheel on an early for column. But im sure somebody fixes stock tapers on original wheels?
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
Old 06-09-2017, 02:45 PM   #2
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: Proper size reamer early ford steering wheel?
Just buy the top portion or the entire 40 steering shaft, cut your column to match the 40 piece and weld it on. Been done many, many times ....
TomT/Williamsburg is offline   Reply With Quote
Old 06-09-2017, 03:23 PM   #3
Ball and Chain
The wheel im using has already been tapered just not down far enough, id rather fix whats there.
Throttle Benders
Est. 1949
Old 06-09-2017, 03:48 PM   #4
FlatheadTed
FlatheadTed's Avatar
Buy a short drill bit and grind it down to the shape you want use a drill press .you will need to reshape the cutting edge so some skill is required ,What about the key way ? Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-09-2017, 03:54 PM   #5
Ball and Chain
good idea, it already has a key way broached into it and been tapered just would like to get a couple more threads out of the nut that holds it on
Throttle Benders
Est. 1949
Old 06-09-2017, 04:20 PM   #6
62pan
If you take your time you could use a file. A friend had a reamer that was close and that is how I finished it. Put a 37 banjo wheel on a Model A shaft.
62pan is offline   Reply With Quote
Old 06-09-2017, 04:40 PM   #7
rotorwrench
rotorwrench's Avatar
I'm not sure what taper those shafts are. Morse and Brown & Sharpe are the most common but a person would have to measure the diameter on one end and the other then use the depth of bore to calculate what the angles to center are. If a person has different sets of reamers then they could just compare them by fit.
This link has different types & sizes of them but it also lists the angles of the taper from center. http://littlemachineshop.com/reference/tapers.php
I've heard Folks mention that the Fords use a 7 degree taper but that still doesn't say what taper it is. Ford or their vendors changed taper types a time or two over the years.
Old 06-09-2017, 06:26 PM   #8
Yoyodyne
Yoyodyne's Avatar
See if a Ford tie rod end matches the steering taper. If it does you can buy tie rod reamers from 4X4 fabrication shops. I had to make one long ago before you could buy them, it turned out to be 1.5" per foot, which is very close to 7°
Yoyodyne is offline   Reply With Quote
Old 06-09-2017, 06:32 PM   #9
38bill
38bill's Avatar
Speedway states their modern steering wheel adapter to early Ford has a 7deg taper. Dont know about the length.
38bill is offline   Reply With Quote
Old 06-09-2017, 07:44 PM   #10
woodiewagon46
I have a steering wheel for my '46 in my stash and I'll pull it out and measure it. Taper reamers aren't cheap so why not take it to a machine shop and have them do it. Ford did some weird stuff so a stock taper reamer might not be available.
woodiewagon46 is offline   Reply With Quote
Old 06-09-2017, 08:16 PM   #11
scrapiron
You will have real problem with a straight flute reamer, trying to work it over a keyway.
scrapiron is offline   Reply With Quote
Old 06-09-2017, 08:25 PM   #12
jake197000
i think you could do it with a dremmel.its not a space shuttle part.oh wait they blew up.
jake197000 is offline   Reply With Quote
Old 06-10-2017, 09:08 AM   #13
rotorwrench
My old lathe has a taper turning attachment but it is limited to the amount of degrees it can bore or cut. If a part was fabricated this way then it may not have a standard taper. I'd figure that it would be a faster process to ream them so my money would be on a standard or a Ford specific standard. The key way was likely cut after the tapering was completed so it does complicate things as to changing an existing taper. The key way can be filled with Devcon to use a straight flute reamer then the Devcon can be removed. It would take a long time to lap it in there.
Old 06-10-2017, 01:32 PM   #14
woodiewagon46
I tried to mic. the '46 Ford steering wheel I have in my parts stash. The length of the taper is about a little over an inch long. The widest part is .750 and the smallest part of the taper is very hard for me to get a calipers in but looks somewhere like .690. Unless I am reading my taper gauge wrong I only get something like a 2 Degree taper. McMaster-Carr has part no. 8798A14 which is a 1/2" pipe reamer that is fairly close but not exact for $65.00.
Old 06-10-2017, 04:02 PM   #15
Tony, NY
Is that the taper from side to side? I think it's 2x what you're measuring if you're doing degrees.
Tony, NY is offline   Reply With Quote
Old 06-10-2017, 05:32 PM   #16
woodiewagon46
Yes, Tony, degrees. I know there are taper sizes, but a machinist I'm not.
Old 06-10-2017, 07:42 PM   #17
38bill
38bill's Avatar
FWIW: Here's what I measure from a steering shaft. The taper is 3.5 deg a side for a total of 7 deg.
Old 06-10-2017, 08:48 PM   #18
Yoyodyne
Yoyodyne's Avatar
If you google tie rod reamers you'll find a big selection and price range. Here's a relatively inexpensive one from Speedway. The left hand spiral will cost more than a straight flute reamer but will help bridge the keyway, and will help prevent the reamer from wedging tight into the tapered hole.
http://www.speedwaymotors.com/Speedw...gree,2918.html
To use one in a hand tool operation you want a straight shank with a square end, not a tapered shank.
Machine tapers like morse and B&S are much shallower tapers than this. Repair reamers may on occasion be 7° or 1.5" per ft, but unless the angle is specified you can't count on that.
