Old 04-26-2017, 06:22 PM   #1
1930marie
1930marie's Avatar
Default motor install: max wt.
Is there any reason to not install the intake and exhaust manifold prior to installing the motor? My rigging consists of using a couple old spark plug bodies placed into the manifold. For that matter, can the starter be installed too? Thanks!
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 04-26-2017, 06:36 PM   #2
Art Newland
Art Newland's Avatar
Default Re: motor install: max wt.
If it's easy to install with the engine in the car, I leave it off. The starter is is very close to the steering box/column so I leave it off too.
Art Newland is offline   Reply With Quote
Old 04-26-2017, 06:56 PM   #3
Benson
1. Good idea to leave the throttle linkage off rear of engine ... It only gets all bent up installing engine . Then it is a PIA to straighten it out later so that carburetor linkage works.
2. when you remove linkage bolts suggest a dab ( 1/2 the size of a pea is all that is needed) of silicone rubber on the edge of the two brass "U" shaped shims where the bolts go through the housing on bolts that hold throttle linkage ... otherwise the shims fall out and get lost.
Shims go between flywheel housing and the block ... (not between bolt head and linkage).
These shims make up for the 0.010 thickness of the gasket between block and flywheel housing and are needed for correct alignment of transmission.
3. Good idea to thread two bolts back into holes and leave them finger tight to hold shims in alignment before silicone is applied..
Last edited by Benson; 04-26-2017 at 07:19 PM. Reason: added corrections and additional info - blue text and black added
Old 04-26-2017, 09:00 PM   #4
SeaSlugs
SeaSlugs's Avatar
i installed mine with everything from fan to u joint on the trans to carb to starter. Of course i was going into a bare frame :P
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-26-2017, 09:22 PM   #5
1930marie
1930marie's Avatar
Thanks for the help. I've been dealing with a really bad back issue and was looking to get as much pre assembly done as possible. I should have stated the body is on. I will forget the short cuts and thanks Mr. Benson for the shims reminder - excellent linkage tip too.
