Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 04-19-2017, 10:00 PM   #1
IndianapolisRacer
Default Traditional 5 window coupe
I have a really nice 1932 five window coupe with a late 8BA flattie and a 1939 trans.and a Columbia 2 speed rear and split wishbone front end . I am installing a 2 inch drop axle and now my problem , because the wishbones are now lower with the dropped axle the drag link will no longer clear the wishbones what is the traditional way of correcting this and #2 the steering rod from the pitman arm is now too short do I splice and weld or again whats the traditional way of fixing this ! Thanks Mike B.
IndianapolisRacer is offline   Reply With Quote
Old 04-20-2017, 10:56 AM   #2
Charlie Stephens
Default Re: Traditional 5 window coupe
You have placed this in a forum intended for questions to the editors. You should move it to the main forum and/or HAMB.
Charlie Stephens
Old 04-21-2017, 10:39 AM   #3
Topher5150
I'm lazy so I'd just get a set of dropped spindle arms
Topher5150 is offline   Reply With Quote
Old 04-21-2017, 10:51 AM   #4
redmodelt
redmodelt's Avatar
This question might be a better fit for the folks over on HAMB as Charlie suggested. http://www.jalopyjournal.com/
This is the kind of stuff the guys over there work on.
