Old 03-29-2017, 09:25 AM   #1
Jonnyenglish
Default flywheel?
More curious than anything but in the picture below what is the one on the left? The set of gears on top drop down in,
Jonnyenglish is offline   Reply With Quote
Old 03-29-2017, 09:30 AM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: flywheel?
It looks like the early clutch assy. for the multi-clutch system.
Gunmetal blue2 is offline   Reply With Quote
Old 03-29-2017, 10:03 AM   #3
Rancho Deluxe
Rancho Deluxe's Avatar
Yes it is the early one, and it looks very worn on the driving teeth & I would bet the fly wheel is also worn to bad to use..
Rancho Deluxe is offline   Reply With Quote
Old 03-29-2017, 10:38 AM   #4
Jonnyenglish
Thanks for the info.
Old 03-29-2017, 12:22 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I'd clean up the clutch pack and flywheel and use it in a 1928 if you have all the rest of the parts to be correct, unless the flywheel is too badly worn. Run a screwdriver tip up and down the internal teeth of the flywheel to see how bad it is notched. Mine looked bad, but after sandblasting, it looked like new with no notching at all.
Old 03-29-2017, 01:40 PM   #6
Tom Wesenberg
Here's the pictures of my multiplate flywheel #4. After sandblasting, it looks like NOS.
https://www.fordbarn.com/forum/showth...ywheel+picture
Old 03-29-2017, 02:24 PM   #7
Jonnyenglish
Looks good Tom, thanks for the link.
