Old 04-10-2025, 07:32 PM   #1
TomC750
TomC750's Avatar
Default Compression
Searched the forum and other places for acceptable compression numbers for my '41 Merc. Mine range between 70# and 80#. Any help?
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 04-10-2025, 08:02 PM   #2
tubman
tubman's Avatar
Default Re: Compression
It'll probably start and run OK with those numbers. Before I changed the engine in my '51, it was between 85 and 100 on all eight and it was OK to drive daily. You may be OK (for a while) if they're all about the same. Hopefully, a couple dosed of Marvel Mystery Oil and some driving will cause the situation to improve. Maybe a couple of shots of Sea Foam down the carb, as well.
Don't expect any "seat of the pants" thrills, though.
Old 04-10-2025, 08:43 PM   #3
TomC750
TomC750's Avatar
Tubman, thanks for the response. This vehicle does not smoke or burn oil. It wants to run strong intermittently, but has a tuneup problem I have not figured out. I do suspect a valve sticking occasionally when listening to the exhaust at idle. But there is something else. I am going to put an ignition analyzer on it tomorrow.
TomC750
1930 1 Ton White
Old 04-10-2025, 08:47 PM   #4
tubman
tubman's Avatar
Check for a weak condenser. Prepare to have to try one or more FLAPS condensers before you get a good one. I hear Vertex magneto condensers are very good, but they have to be special ordered.
Old 04-11-2025, 07:51 AM   #5
34fordy
34fordy's Avatar
I have no idea what a "flaps" condenser is and the Mallory is good but I would try a "TUBMAN TRASHCAN" for peace of mind!
34fordy is offline   Reply With Quote
Old 04-11-2025, 07:56 AM   #6
corvette8n
corvette8n's Avatar
My ‘41 is 60lbs on all 8 and it burns a quart every 40 miles, but I still drive it to car shows several times in the summer. Post some pictures of your Merc, I almost bought a two-tone 1941 Mercury w/jump seats but the paperwork was wonky so I passed.
Old 04-11-2025, 09:05 AM   #7
tubman
tubman's Avatar
Sorry, "H.A.M.B. term". "FLAPS" - Friendly local auto part store.
For the record, I am now out of condensers. Any future supply depends on whether I can talk my partner into making some more when I get back to Minnesota.
Old 04-11-2025, 10:07 AM   #8
mfirth
Stores like N A P A. Standing joke here is : Never Any Parts Available. The guys who work there are actually GR8 & get what they don't have next day.
mfirth is offline   Reply With Quote
Old 04-11-2025, 10:26 AM   #9
Drbrown
Drbrown's Avatar
Regarding concern about valves, attach a vacuum meter at you carb. If the indicator needle stumbles, jumps etc it could indicate a sticky or badly seated valve. This is not unusual for engines that don't get enough use. If so, next step might be to add some MMO .... a bit down the carb and a quart in the oil. At purchase my '47 had same symptom and the MMO cleared it up.
Drbrown is offline   Reply With Quote
Old 04-11-2025, 12:24 PM   #10
TomC750
TomC750's Avatar
I had a vacuum gauge on my engine, it fluttered a little bit, I did run some Seafoam through it, no change. It is not one valve that is a problem, it stumbles on all cylinders intermittently. I am going to do the MMO however.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:27 PM   #11
TomC750
TomC750's Avatar
Charlie installed a new condenser, (NAPA) possible it is bad I suppose. I had my old ignition analyzer on it this morning, rather inconclusive. blurry trace, jumped around quite a bit.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:30 PM   #12
TomC750
TomC750's Avatar
When it pulls, it pulls strong, even when missing intermittently.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:40 PM   #13
tubman
tubman's Avatar
That's encouraging.
