Old 03-09-2017, 07:30 PM   #1
biggieou
Default 1950 Mercury Motor Mount
Where can I pick up the rubber motor mounts for the Mercury?
Sent from my SM-N920V using Tapatalk
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 03-09-2017, 08:32 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1950 Mercury Motor Mount
Mac's for one vendor.
Old 03-09-2017, 10:32 PM   #3
Paul Bennett
Several supplier have mounts in their catalog/web pages but a morning of phone calls establishes them NLA except for MACs. I'm also placing an order tonight. Total cost for 2 is about $73 incl shipping. According to research I've done the bolts are often in bad shape as well.
Incidentally the upper nut requires a 15/16" socket, not in everyone's kit.
Paul Bennett is offline   Reply With Quote
Old 03-10-2017, 09:38 AM   #4
19Fordy
19Fordy's Avatar
I think you can also use the ford truck motor mount rubbers and also the 1940 ford rubber motor mounts. That will save you lots of money.
http://dennis-carpenter.com/trk48-56motor-mounts/c/554/
19Fordy is online now   Reply With Quote
Old 03-10-2017, 09:46 AM   #5
biggieou
I just reached out to Van Pelt and they have the biscuits. Will save you about 50 bucks versus the fleecing that is Macs.
1950 Mercury 8
Old 03-10-2017, 10:32 AM   #6
rotorwrench
rotorwrench's Avatar
The part number changed for the later 50s pickup mounts but they are the same as the mercury parts. If it weren't for those, they probably wouldn't be available any more.
Old 03-10-2017, 01:06 PM   #7
bssmnbll
bssmnbll's Avatar
I replaced my pads on a 50 Merc with pads I had for a 63 Studebaker Avanti, same thing.
bssmnbll is offline   Reply With Quote
Old 03-10-2017, 01:49 PM   #8
JSeery
JSeery's Avatar
Are we talking apples and oranges here? I not sure from the post, but looks like we might be comparing the price of the pads with the price of a kit that includes the bolts, hardware and pads.
Update: Looked on LMC and even as a kit the $73 price seems high (IF these are the same parts).
Old 03-10-2017, 02:11 PM   #9
rotorwrench
The late 49 through early 51 Mercury mount pads are different and use different larger diameter hardware plus they use them on the transmission too for the ones up through the early 51. The early 1949 stuff was he most oddball stuff made. There may be someone making those front ones now but they had to be rebuilt for a long time. 8M-6038 and 8M-6039 are the part numbers.
Old 03-11-2017, 01:25 AM   #10
Paul Bennett
I unfortunately placed my order last night before seeing today's posts. Illustrations abound but no dimensions are available even in the Lincoln/Merc shop manual. Some phone clerks were insistent about the 8M6038 and 9 are larger than the F1 equivalent.
I will post the measurements of what I get from Mac's. And anyone else please do the same with the F1 or other motor mounts. We should get this settled for the benefit of those who follow our path.
I'm not pleased about paying $26 for a single rubber available elsewhere for $6 and can only hope there is a meaningful size difference.
Old 03-11-2017, 07:46 AM   #11
Frank Miller
Frank Miller's Avatar
Smile Re: 1950 Mercury Motor Mount
Don't we all
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 03-11-2017, 07:52 AM   #12
biggieou
That stinks Paul, bit I appreciate measuring and posting on here. I would just return them. I always go with Macs last, whether it was for my 48 F1 or my Model A.
1950 Mercury 8
Old 03-11-2017, 10:59 AM   #13
rotorwrench
The Mercury parts are vulcanized around a metal disc and are taller/thicker than the Ford parts plus they have a protrusion on the bottom that the lower cushion piece fits over like a pilot stub when placed through the mount hole in the frame. The shoulder bolts are unobtanium so I hope yours are still good. I make new ones with aircraft grade bolts and bushings.
I think Mac VanPelt handles them but I don't now who all might have them in stock. I see originals on flea-pay now and then but the rubber is likely 50-years old or better.
