Old 03-25-2017, 07:44 PM   #1
hombres ruin
hombres ruin's Avatar
Default Hand throttle is it needed?
Hi guys installing a new carb and was wondering what people think about the hand throttle linkage. Would it be ok to do away with it or is it a handy item to have. What have you guys done in the past ? Thanks
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 03-25-2017, 08:35 PM   #2
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Re: Hand throttle is it needed?
I don't have mine hooked up. The knob is there for "display" only and the cable end pokes through the firewall, but that's where it ends.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 03-25-2017, 08:47 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I use mine occasionally, and wouldn't want to delete the convenience of having it there if/when needed.
John
Old 03-25-2017, 09:06 PM   #4
Lawrie
Lawrie's Avatar
I have just done about 7000 klms in our 33,most on back roads,it is so nice to be able to give the gas foot a rest every now and then with the hand throttle.
lawrie
Old 03-25-2017, 10:22 PM   #5
MGG
MGG's Avatar
I use the hand throttle in starting out on from uphill stop.
MGG is offline   Reply With Quote
Old 03-26-2017, 05:23 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Suspect that one of the main reasons for having one (other than providing higher RPM for un-attended warm up) was to be used in conjunction with the different power belt attachments that were driven off one rear wheel back in the day. (saws,water pumps etc.)
Old 03-26-2017, 08:32 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
I use mine all the time - especially to warm the engine up when it has sat for awhile.
Old 03-26-2017, 10:28 AM   #8
Ford Freak
Does the hand throttle stay open when you let go , or does it have a spring to return to idle when not holding the knob ?
Ford Freak is offline   Reply With Quote
Old 03-26-2017, 10:35 AM   #9
19Fordy
19Fordy's Avatar
Stays open. If not, use a clothes pin.
Sure is handy in cold weather warm up.
Old 03-26-2017, 10:39 AM   #10
Brian
Brian's Avatar
On my 35 it'll return to idle once you release the knob.
Old 03-26-2017, 10:49 AM   #11
5851a
Surely Henry would not have included it if it wasn't necessary. I can see more use for it back in the day.
5851a is offline   Reply With Quote
Old 03-26-2017, 11:00 AM   #12
glennpm
glennpm's Avatar
Mine slips back in. I don't know how to apply more friction to it. It is convenient for fast idle during startup.
Originally Posted by 19Fordy View Post
Stays open.
Old 03-26-2017, 11:06 AM   #13
blucar
blucar's Avatar
By the mid to late '30's the hand throttle was pretty well a thing of the past, especially since the Ford type would not hold its position when hand was released.
I utilized the hole in the dash for a headlight switch when I eliminated the original steering wheel mounted rotary switch.
On a truck/utility vehicle the hand throttle could be handy if the vehicle had a PTO for a dump body, etc..
Fords design of the hand throttle left a lot to be desired, there was no provision in the EFV8 for a way to set and/or hold the hand throttle into a given position.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 03-26-2017, 11:21 AM   #14
Capt Kirk
Capt Kirk's Avatar
I'm having the same problem and was wondering if I did something wrong when restoring it. The only thing I can think to do is get another dash grommet with a tighter fitting hole.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 03-26-2017, 11:40 AM   #15
Scotty's 52 F3
Scotty's 52 F3's Avatar
My hand throttle would hold up to a point. Then I made the mistake of cleaning and lubing it.
I have used hand throttle cables on different types of equipment that once pulled to desired RPM's, you twist to lock.
Scotty's 52 F3 is offline   Reply With Quote
Old 03-26-2017, 11:46 AM   #16
Vintage Copper 47
Vintage Copper 47's Avatar
The linkage at the carb was real loose & would slip past making the cable useless.. so I removed it.. used the hole there for an aftermarket/momentary ignition keyed switch...
Vintage Copper 47 is offline   Reply With Quote
Old 03-26-2017, 12:27 PM   #17
ford38v8
ford38v8's Avatar
I never saw one that would hold position once released. Now you got me thinking, I wonder if a sawtooth bottom edge could be made to hold it steady in the slot.
Alan
Old 03-26-2017, 12:53 PM   #18
drolston
drolston's Avatar
You will be glad to have it if you ever have someone pull up close behind you when stopped on a hill. Especially if your flathead hesitates a little when you punch it off idle. I went to a lot of trouble rigging the progressive linkage on my 3 x 2 manifold to retain the hand throttle. Like putting the carbs on 2" risers so I could invert the linkage. Bonus: That also allows me to use banjo fittings at the fuel inputs instead of a fuel log and fuel lines all over the place.
Old 03-26-2017, 02:03 PM   #19
RalphG
RalphG's Avatar
Its been a good many years since I've used the hand throttle on the 39 Ford, mainly because it has not been running. As I recall it was a handy thing to have and it worked well. Just pull it to set the high idle speed I wanted and it stayed there. Maybe an old rusty cable is a good thing for that purpose. I have a hand throttle on an IH truck that works well and holds position. The manual choke is supposed to have enough of a cam to keep the idle up for warm up but sometimes I wanted a little more rpm.
RalphG is offline   Reply With Quote
Old 03-26-2017, 02:22 PM   #20
40 Deluxe
We used to call them Oklahoma cruise controls.
