Old 02-28-2017, 10:30 AM   #1
1bali-rod
Default Need Simple Ignition Wiring - Ford Model a Help
Hello
Anyone out there on Ford Barn have a very simplified version of an Ignition wiring diagram. Just the basics
No head lamps or tail light.
JUST WHAT IS NEEDED TO MAKE THE CAR RUN.
I Just want to use all factory 4cyl. parts and look .
thanks for anything in advance.
Andy Bali-rod
1bali-rod is offline   Reply With Quote
Old 02-28-2017, 10:43 AM   #2
katy
katy's Avatar
Default Re: Need Simple Ignition Wiring - Ford Model a Help
Try this one:
Old 02-28-2017, 11:33 AM   #3
Art Newland
Art Newland's Avatar
If all you want to do is run the engine, this is all you need.
Art Newland is offline   Reply With Quote
Old 02-28-2017, 12:16 PM   #4
SeaSlugs
SeaSlugs's Avatar
yup - doesnt get any simpler than that...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-28-2017, 12:39 PM   #5
Tom Endy
Tom Endy's Avatar
Attached is a simple drawing of the Model A electrical circuit.
Tom Endy
Old 02-28-2017, 02:29 PM   #6
1bali-rod
Originally Posted by katy View Post
Try this one:
RAD
thank you
Old 02-28-2017, 02:31 PM   #7
1bali-rod
Can you explain a bit.?
1 side screws into distributor and the othe side of the Coil goes where?
thanks
Old 02-28-2017, 02:40 PM   #8
SeaSlugs
SeaSlugs's Avatar
starter terminal (aka battery)
clipping it on acts like turning the ign switch on so clip it on and start it up - dont leave it hooked up when not running! disconnect it with the engine running to shut the engine off.
If you use this method ground the generator output or it will try to charge nothing and cook itself
Old 02-28-2017, 03:39 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
1 side screws from the coil goes into distributor and the othe side of the Coil goes to the none ground side of the battery
thanks
Hot side of battery (red wire with clip) to coil, other side of coil to distributor. Distributor to movable side of points. Stationary side of points grounded to engine. Engine to ground side of battery.
