Old 02-17-2017, 08:57 AM   #1
steve fritz
Default 1940 Ford noisey trunk springs fix??
Has anybody experienced really noisey trunk springs on there Ford coupes?
These are new Bob Drake springs , they work fine and stay up as they should , but wow do they sound creaky! Has anybody come up with a cure for this?
Thanks for any ideas.
Steve
steve fritz is offline   Reply With Quote
Old 02-17-2017, 09:03 AM   #2
PeterC
PeterC's Avatar
Default Re: 1940 Ford noisey trunk springs fix??
Actually my originals sound as you describe as well - I just thought it as normal...
PeterC is offline   Reply With Quote
Old 02-17-2017, 09:12 AM   #3
Vonn Ditch
Yes those springs were designed by Ford to squeak loudly as a theft deterrent.
Vonn Ditch is offline   Reply With Quote
Old 02-17-2017, 09:45 AM   #4
TJ
TJ's Avatar
I've had '40s with original springs and they sounded no different than the repos.
Old 02-17-2017, 10:15 AM   #5
19Fordy
19Fordy's Avatar
The probably squeak because they are new.
Will settle in with use and a drop or two of oil on the big hinge rivet and where spring rests.
Neither my originals nor DRAKE's repros squeaked.
Maybe you have a "mouse in the house".
Old 02-17-2017, 11:53 AM   #6
Kube
Kube's Avatar
Steve
I've had literally dozens of '40 Fords and never once experienced a squeak from the trunk lid supports.
Did you place a piece of anti-squeak material between the lid and upper mount? It was there originally. The authentic material was similar to a heavy gasket (paper) material.
Old 02-17-2017, 12:02 PM   #7
steve fritz
Thanks KUBE I will try that. Really appreciate your help, you are a great asset to the Ford Barn.
Steve
Old 02-17-2017, 02:16 PM   #8
19Fordy
19Fordy's Avatar
I bet "Kube" is onto something. Maybe the squeak is coming from the trunk lid hinges that attach the trunk lid to the car body - not the trunk lid hinges that hold the trunk lid "UP".
Old 02-17-2017, 02:51 PM   #9
ricklove
ricklove's Avatar
I sprayed mine with WD40 - all noise gone!
ricklove is offline   Reply With Quote
Old 02-21-2017, 08:13 PM   #10
steve fritz
I ended up installing some gasket material between spring brackets and the trunk lid , then used some 3 in 1 oil on the two contact points on the coil spring. One in the middle of the coil and one on the very end stop of the spring. I would say the springs are now much quieter and not as noticeable when I open and close the trunk lid.
Thanks to all,
Steve
Old 02-22-2017, 01:52 PM   #11
Chris
Chris's Avatar
Good to know, I installed new trunk supports on my 46 coupe and they squeak as well
Thee Inland Emperors
Chris is offline   Reply With Quote
