Old 12-29-2016, 09:22 AM   #1
karsyn
Default 40 ford coupe
Would like to install a Ford Coyote motor in my 40. Any advice on how it will fit?
karsyn is offline   Reply With Quote
Old 12-29-2016, 09:29 AM   #2
mrtexas
mrtexas's Avatar
Default Re: 40 ford coupe
Ask on HAMB
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 12-29-2016, 09:41 AM   #3
V8 Bob
V8 Bob's Avatar
Originally Posted by mrtexas View Post
Ask on HAMB
Probably not gonna be liked on the HAMB, but he can try...
Old 12-29-2016, 10:29 AM   #4
Karl Wescott
Karl Wescott's Avatar
Most of this group is uncomfortable with the likely surgery required as you may need to cut the firewall for clearance and cut the frame cross member for transmission clearance. You also may or may not have clearance issues with the inner fenders. The oil filter may interfere with some steering boxes. Exhaust routing might be an issue.
You will likely have to do your own engineering or find a shop who will. Ultimately you have to stuff the motor in, remove any offending original sheetmetal, and then rebuild any structures you have compromised.
Once you get the dirty work done, the guys here are usually very nice about helping with issues of body fit and original parts interchanges.
Karl Wescott is offline   Reply With Quote
Old 12-29-2016, 10:34 AM   #5
19Fordy
19Fordy's Avatar
karsyn, Here's a Coyote stuffed in a 40 ford.
https://www.youtube.com/watch?v=zaTmCubiN68
Old 12-29-2016, 12:59 PM   #6
Milt/Las Vegas
Milt/Las Vegas's Avatar
Why wouldn't they like this on the HAMB?If I hadn't been so heavily invested in 351s I would have done this.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
Old 12-29-2016, 01:00 PM   #7
Milt/Las Vegas
The engine is really wide but is very short,and is light.
Milt/Las Vegas
Old 12-29-2016, 01:07 PM   #8
V8 Bob
V8 Bob's Avatar
Putting a Coyote in the '40 isn't a bad idea, but the HAMB's main focus is pre-'65 traditional. Some later things they'll allow, most they won't.
Old 12-29-2016, 02:14 PM   #9
JSeery
JSeery's Avatar
Way outside their (HAMB) time frame. The HAMB is for more traditional Hot Rods vs modern Street Rods.
Old 12-29-2016, 07:36 PM   #10
russcc
Saw a completely stock looking '40 deluxe coupe, with great patina at Bonneville several years ago with a Coyote in it. Everything else was stock, very cool.
Old 12-29-2016, 07:49 PM   #11
deuce_roadster
deuce_roadster's Avatar
Really, a stock transmission,rear end, brakes behind that engine? Sounds pretty unsafe to me.
Old 12-30-2016, 11:08 AM   #12
SofaKing
SofaKing's Avatar
It'll actually be very safe as that engine will destroy any stock driveline components in short order. Though I doubt that is the plan.
I have to wonder given the question and the magnitude of the modification if the car won't be for sale shortly after reality sets in.
Nothing is as easy as it appears on TV.
SofaKing is offline   Reply With Quote
Old 12-30-2016, 12:02 PM   #13
Milt/Las Vegas
I didn't know that.There doesn't seem to be any forum for late model ford engines into early fords.
Milt/Las Vegas
Old 12-30-2016, 12:08 PM   #14
Milt/Las Vegas
Why would you use a stock drive train?In my 40 conv.project I have a recessed firewall,a TCI frame,and a 9 inch rear end.So a coyote with a 6 speed auto would have been great.Instead I have 408 clevor with a c6 and a gear vendors overdrive.
Milt/Las Vegas
Old 12-30-2016, 12:15 PM   #15
Milt/Las Vegas
Why would you use a stock driveline.In my 40 conv project I have a TCI frame with a 9 inch rear end,a 408 clevor,a c6 and a gear vendors overdrive,with a recessed firewall,but a coyote with a 6 speed auto would have been nice.
Milt/Las Vegas
Old 12-30-2016, 02:42 PM   #16
bill3337
bill3337's Avatar
Try Streetrodding.com for this question. It leans more to the street rod culture. I've belonged to it for years.
bill3337 is offline   Reply With Quote
Old 12-30-2016, 04:47 PM   #17
karsyn
Thanks all
Old 01-11-2017, 03:46 PM   #18
geoford41
geoford41's Avatar
Street rodder Magazine did the entir '40 Ford coupe buidl on a "carpenter" steel body (with a slight chopped top) and the Ford Coyote engine. LOTS of work!
geoford41 is offline   Reply With Quote
Old 01-12-2017, 12:33 PM   #19
Pomeroy41144
Pomeroy41144's Avatar
It wasn't SofaKing. Go back and read Post # 10; that is the fella who noted a 40 with coyote and all else stock. Sofa was just responding to that.
russcc Re: 40 ford coupe
Pomeroy41144 is offline   Reply With Quote
Old 01-12-2017, 01:16 PM   #20
Milt/Las Vegas
I didn't know this.What forum would be receptive for this then?
Milt/Las Vegas
