Old 01-08-2017, 09:22 AM   #1
Pinesdune
Pinesdune's Avatar
Default Spray adhesive
What do you folks recommend as a spray adhesive to glue the top bow drill material to the cardboard fillers. I tried a spray contact cement but it bled through
The bow drill didn't like storage for forty ish years
Pinesdune is offline   Reply With Quote
Old 01-08-2017, 09:45 AM   #2
jm29henry
jm29henry's Avatar
Default Re: Spray adhesive
3m makes a interior spray glue works very well !!! Best of luck to you on your project.
jm29henry is offline   Reply With Quote
Old 01-08-2017, 09:52 AM   #3
davehc
davehc's Avatar
I just used this Elmer's Spray that my wife had used on some sewing projects and it worked fine for me , seemed to hold pretty good .
davehc is offline   Reply With Quote
Old 01-08-2017, 10:04 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
My neighbor just had the sagging headliner in his 2003 Buick replaced, and the woman used 3M Super Adhesive #77. She used a wire brush to remove all the old foam from the headliner form, then sprayed both surfaces and let it set up for a few minutes, then pressed them together. I think that is the same spray I saw Elizabeth use when she installed a Model A headliner.
http://www.ebay.com/itm/3M-Super-77-...AAAOSw8gVX-RgI
Old 01-08-2017, 10:15 AM   #5
JDupuis
JDupuis's Avatar
Hey Pinesdune, do you live at Grandbend? If so we've spoke at different flea markets.
As to gluing, I've only glued on the back side of the panels. Gluing the excess material on the hidden side of the panel. Yes allowing time for the glue to "set-up". By gluing only the back of the panel, you can remove any wrinkles that may occur now or in the future. Hope this helps. Jeff
JDupuis is offline   Reply With Quote
Old 01-08-2017, 10:57 AM   #6
Pinesdune
Pinesdune's Avatar
Thanks guys, I'll track down some 3m.
JDupuis, I live near Neepawa, you may be thinking of someone else, but I have met a few folks at swap meets, were you at the swap at the Ex last spring or the one beside the Winnipeg auto museum the beginning of August? I did try just glueing a panel on the back lip but when formed to the shape of my roof, the material sags bad and needs to be adhered completely to the panels face.
Thank you guys, I'll post pics when she's done
Old 01-08-2017, 11:23 AM   #7
SSsssteamer
SSsssteamer's Avatar
Ditto. Works great.
SSsssteamer is offline   Reply With Quote
Old 01-08-2017, 11:34 AM   #8
todd3131
todd3131's Avatar
I use 77 for light applications but I recommend 3 m super 90 it is for high strength application I have had failures with the 77 but never the 90.
todd3131 is offline   Reply With Quote
Old 01-08-2017, 11:38 AM   #9
JDupuis
JDupuis's Avatar
Sorry Pinesdune; you and I have never met then. Have never gotten over that direction. I guess I was mistaking you with some other incredably handsome fello, alot like myself. All the best. Jeff
Old 01-08-2017, 11:43 AM   #10
V4F
V4F's Avatar
we used it farm equipment & I use it on my floor in my "A" . works great , be sure to clean the tip & can after use
V4f
V4F is offline   Reply With Quote
Old 01-08-2017, 01:28 PM   #11
Pinesdune
Pinesdune's Avatar
And you have a great day fine sir [emoji1303]
Old 01-11-2017, 11:30 AM   #12
Pinesdune
Pinesdune's Avatar
The 3m adhesive did the trick, thanks for the responses
