Old 01-12-2017, 05:00 PM   #1
vern hodgson
Default Choke rod
Not having one to look at, what is the mechanism which keeps the choke rod from pulling out thru the firewall?? When I use the choke it aiplwaysvpulls loose from the GAV?
vern hodgson is offline   Reply With Quote
Old 01-12-2017, 05:20 PM   #2
d.
Default Re: Choke rod
check the catalogs...there is a sleeve and a spring to keep things where they need to be. Brattons has a good diagram of this and the pieces needed are inexpensive, so get it set up correctly and enjoy.
d. is offline   Reply With Quote
Old 01-12-2017, 07:32 PM   #3
Beauford
The two rods connect together with notches. You then slide over sleeve and it stays put.
Beauford is offline   Reply With Quote
Old 01-12-2017, 07:47 PM   #4
Smooth_One
Smooth_One's Avatar
I just went out and snapped a pic of my car.
Smooth_One is offline   Reply With Quote
Old 01-12-2017, 08:53 PM   #5
duke36
too much play between the choke lever ( raised bump on the lever) and gav sleeve recess?
Old 01-13-2017, 04:56 AM   #6
vern hodgson
By Jove, I think you've got it. Thankew
