Old 12-30-2016, 12:02 AM   #1
Tanglfoot
Default Stromberg 97
I am looking for some advice when fitting a Stromberg 97 carb to my warmed up A Roadster.
IE: jet sizes etc. I am not using a fuel pump as it seems to be going ok with gravity and near empty tank. However it just spits and farts when going through the gears. Does anyone have experience with the 97/ MA combination?
Cheers, Ross in sunny NZ.
The older we get the better we were.
Tanglfoot is offline   Reply With Quote
Old 12-30-2016, 12:16 AM   #2
PC/SR
Default Re: Stromberg 97
Sounds lean. You may need fuel pressure.
PC/SR is offline   Reply With Quote
Old 12-30-2016, 01:04 AM   #3
Tanglfoot
Thank you ps/sr you may be correct I am trying to do it without a pump as I had a 94 without pump and it worked ok at low level tank, just thought the 97 would be better as the inlet is 35mm/1 1/4 lower than the 94.
cheers
Old 12-30-2016, 08:59 AM   #4
CarlG
CarlG's Avatar
I tried using Mr Gravity, but he just didn't work so well. Fuel pump fixed that bigtime.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-30-2016, 09:02 AM   #5
Dave in MN
Dave in MN's Avatar
I recently completed some dynamometer testing on two engines. In both cases we tried to gravity feed a single Stromberg 97 carb and found we could not develop power under a heavy load. When we added a fuel pump to raise the fuel line pressure to 2.5#, the problem ceased.
On one of the engines, we also tried a pair of 48's and a pair of 94's. They were a bit more forgiving. I did not try the 94 as a single but did test a single 48 and when doing so, it had the same loss of power under heavy loading.
Hope you find your solution.
Good Day!
Dave in MN is offline   Reply With Quote
Old 12-30-2016, 10:50 AM   #6
Phred
Phred's Avatar
Rule of thumb for single 97 carb, flathead banger
Main Jets #45 for 0 - 5000' elevation
jet down 2 sizes for 5000' - 10000'
jet down 2 more sizes for 10000' +
Based on information from the English Stromberg manufacturer and my experiences.
Phred is offline   Reply With Quote
Old 12-30-2016, 01:23 PM   #7
Tanglfoot
Thank you to you all for your help looks like I need a pump.
Old 12-30-2016, 01:39 PM   #8
1929
I have a single 97 with a 3/8 fuel line, its ok on gravity until I try to stay at 60mph and over. At a lower constant speed its ok, I would suggest that if you go with the pump, always keep an extra line of fuel hose in the car if ever the pump or regulator fails
1929 is offline   Reply With Quote
Old 12-30-2016, 03:54 PM   #9
Juggler
Juggler's Avatar
I like the Carter P60504. It's a 12v pump but produces about 2 psi if you run it on 6v
Cheapest I've found is at Rockauto for about $30
Fits neatly in the frame rail and is almost silent
Juggler is offline   Reply With Quote
Old 12-30-2016, 04:45 PM   #10
Lawrie
Lawrie's Avatar
My 97 works great on gravity feed,I made my own float valve and it will make full power up a hill with a nearly empty tank.
Will post some pics if you want,a very easy thing to do,and so far trouble free,(20,000 kms)
Lawrie
Old 12-30-2016, 05:02 PM   #11
34 FORDOR
34 FORDOR's Avatar
I have a 97 on my 30 Tudor , started out with no pump and had similar problems . The needle / float valve needed some pressure to open . I modified the valve , but still wasn't 100 per cent , so gave up and fitted a pump , no more problems . Lawrie may have the remedy with his valve.
34 FORDOR is offline   Reply With Quote
Old 12-30-2016, 05:23 PM   #12
scicala
scicala's Avatar
Tanglfoot,
I think you need to do like Lawrie did. Modify the fuel valve on the carb by opening up the orifice size a little at a time. Stake it lightly with a solid steel fuel valve needle after drilling to ensure a good seal. You're issue isn't because the jets are too small. With the head pressure from the fuel tank, you probably only have around 1 PSI max. (1/2 PSI for every foot of head pressure). You're problem is that you can't get fuel in the carb fast enough without a fuel pump with a standard small orifice in the fuel valve.
Sal
scicala is offline   Reply With Quote
Old 12-30-2016, 08:46 PM   #13
Lawrie
Lawrie's Avatar
What I did was to open up the inlet hole slightly,but the main thing was to fit a little gizmo to pull the valve off its seat when the float drops.
I used the spring loaded pin assy from an old 97 power valve,drilled a hole in the end of the needle valve, drilled a small hole in the float part that pushed onto the needle valve,fit the pin and spring through and pressed the pin and spring assy into it the needle valve,this has been on my A for 8 or 10 years.
Lawrie
Old 12-31-2016, 12:48 AM   #14
Tanglfoot
Thank you again to all you very clever people, SBcarb,34 fordor,scicala,juggler.1929 and Lawrie. I will try Lawrys method first.
Cheers
Rosco
Old 12-31-2016, 04:34 AM   #15
Dodge
Lawrie.....Brilliant!
Dodge is offline   Reply With Quote
Old 12-31-2016, 04:18 PM   #16
Gavin
I can see you undertaking the suggestion from Lawrie as a very interesting challenge given your approach to such things Ross. I had similar issues with the Weber on my Roadster - ok till hills or acceleration were required. The Carter pump solved the problem. Happy New Year from Great barrier Island.
Gavin is offline   Reply With Quote
Old 12-31-2016, 09:37 PM   #17
bmodeltman
Would Lawrie's idea work with two stromberg's
bmodeltman is offline   Reply With Quote
Old 12-31-2016, 09:42 PM   #18
DaWizard
Send a message via AIM to DaWizard
Ya know, with my experiences using 97s I would say yes, but the metering might be a wee bit different depending on how you have them fueled.
Oh, ya know, now that I think about how he did it, I would say they could be done the same to each and it should work because it is depending on float height to close off the orifice.
Sure, should work.
My 2¢ worth
DaWizard is offline   Reply With Quote
