Old 10-05-2016, 06:19 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Vacuum reading 276 L-100 cam?
Does 13" of vacuum sound about right?
36tudordeluxe is offline   Reply With Quote
Old 10-05-2016, 09:21 PM   #2
40 Deluxe
Default Re: Vacuum reading 276 L-100 cam?
What is your idle RPM? That affects the vacuum reading.
Old 10-05-2016, 09:33 PM   #3
Ol' Ron
Ol' Ron's Avatar
13 is alittle low, but not much. The last one I checked was 15. I can ask My friend Rob what his 294 is.
Old 10-05-2016, 09:40 PM   #4
Talkwrench
Talkwrench's Avatar
Twin carbs or single ?
Old 10-05-2016, 09:45 PM   #5
40cpe
40cpe's Avatar
and initial timing
Old 10-05-2016, 10:01 PM   #6
36tudordeluxe
Idle was at 600 RPM, will try at 750RPM, single 4 barrel with air cleaner on and initial advance not sure about, just set it so it would fire right up.
Old 10-05-2016, 10:47 PM   #7
Talkwrench
Talkwrench's Avatar
Try advancing until you get your highest reading then back it off about 1 1/2Hg [1.5Hg] then see what it is. Shouldn't need to idle that high ..
Old 10-05-2016, 11:43 PM   #8
36tudordeluxe
I'll give it a go tomorrow at 600 RPM and see what I get.
Old 10-06-2016, 02:29 AM   #9
40 Deluxe
Altitude and compression ratio also factor in.Vegas is about 2,000 ft., I think. So the effect should ber relatively small. But the lower the compression, the quicker altitude affects the vacuum reading, and performance.
Old 10-06-2016, 08:03 AM   #10
Ol' Ron
Ol' Ron's Avatar
Initial advance is not that important, as long as the engine starts. Then the Vac adv will add enough advance for idle. However that's part of the tuning process. setting the AF and ign curves. Done right you'll have a fine running engine with good power and economy. A good starting point is: 2-4 initial. 16 mechanical all in by2000. and 8 vacuum.
With the right AF in the carb youll be in the ballpark for most engine combinations.
Old 10-06-2016, 10:14 AM   #11
36tudordeluxe
Compression ratio is about 8.2:1. Am only getting about 9 MPH, don't have a 5th gear, running a 3.55 in the rear and large diameter tires. Currently have setup #11 in the EDELBROCK manual, am going to try #10 with different metering rods but same jets.
Old 10-06-2016, 04:55 PM   #12
40 Deluxe
Changing main jets and/or metering rods will not affect idle mixture nor vacuum readings unless the throttle opening is so large that fuel is being pulled from the venturiis. At idle only the idle circuit should be feeding the engine. I think your Edelbrock manual has diagrams showing this.
Only 9 MPG means you have other problems than idle vacuum.
Old 10-06-2016, 05:24 PM   #13
Ol' Ron
Ol' Ron's Avatar
Set that up on #8 and give it a try
Old 10-06-2016, 05:48 PM   #14
36tudordeluxe
Jets and rods are for the bad MPG, knew it wouldn't solve low vacuum.
Old 10-06-2016, 05:49 PM   #15
36tudordeluxe
Will try it. BTW, the needles isn't a steady 13, it bounces around between 11 & 13.
Old 10-06-2016, 10:01 PM   #16
Ol' Ron
Ol' Ron's Avatar
You might waht totake a compression check, you might have a bad cylinder.
Old 10-07-2016, 12:01 AM   #17
36tudordeluxe
Going to do that first thing in the morning.
Last time I checked cold was 1- 150 2 -150 3 -145 4 -150 5-154 6-140 7-142
8--135
Old 10-07-2016, 12:24 PM   #18
37don
If you are testing vacuum with a piece of hose on your gauge just bend the hose to restrict the line and the needle will settle down. iI have between 14 & 15 with my 276 and l 100.
Regards, Don.
37don is offline   Reply With Quote
Old 10-07-2016, 12:29 PM   #19
40 Deluxe
Regards, Don.
14 or 15 at sea level in Rhode Island would easily drop to 13" in Las Vegas at 2,000 ft. + above sea level.
Old 10-07-2016, 02:18 PM   #20
36tudordeluxe
I was being too optimistic about my 13" reading, more like 11-12. At my location in the valley here am about 2500' ft. ASL
UPDATE: Have run cold compression test and have lost about 5lb. on average on all cylinders except cyl. #5 which lost 25lb. from 140lb to 115lb. The other cylinders in the 130lb.-145lb. range. Would the low vacuum be explained by the one weaker cylinder? Am going to put in a little more advance at idle and see if this helps.
