Old 10-04-2016, 07:46 AM   #1
Bill in NJ
Default Modify floor boards
I am looking to find the article that shows how to modify the floor boards to make it easier to take the battery out. I am certain it was in one of the clubs magazine but which one and when ? Thanks for any help
Bill in NJ is offline   Reply With Quote
Old 10-04-2016, 08:31 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Modify floor boards
Rather than modify the floorboards, I would just leave the mounting screws out. That way it is easy to lift out the board. Actually I don't even worry about the battery because mine is over 12 years old and I've never had to remove it for any reason. Lifting out the board does make it easier to take pictures for the people that want to see how the speedometer cable runs, etc.
Old 10-04-2016, 08:32 AM   #3
1930artdeco
1930artdeco's Avatar
MAFCA and I think it was the last one in the tiny tips section.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-04-2016, 08:42 AM   #4
Bill Z
Bill Z's Avatar
I just ran across that article by Jim Moss in the July-August 1993 issue last week. The previous owner of my coupe gave me about 20 years worth of the "Restorer" magazine. Lots of great reading!
Bill Z is offline   Reply With Quote
Old 10-04-2016, 08:48 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Snyder's has a kit that allows you to remove half of the floor board (the drivers side). Works really well. Undetectable with the carpet in place.
http://www.snydersantiqueauto.com/fl...-removal-plate
http://www.snydersantiqueauto.com/Co...10671-3737.pdf
Old 10-04-2016, 01:28 PM   #6
springerpete
springerpete's Avatar
I just figured out the size hole needed, cut it out and fitted a large piece of heavy sheet metal over the hole I bolted a piece of 1/2" plywood to the bottom of the sheet metal cut just smaller than the new floorboard hole so the sheet metal cover would not wander. Drilled a finger hole too. Works fine for me.
springerpete is offline   Reply With Quote
Old 10-04-2016, 02:01 PM   #7
JOHN CT
JOHN CT's Avatar
How many times do you take your battery out
I don't mind removing the floor boards. Maintenance is number one in my book. I grease the throwout bearing, Oil the pedal shaft, and just do a visual inspection of the moving parts. My floor boards are not screwed down they fit nice and tight.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 10-04-2016, 04:31 PM   #8
30ccpickup
30ccpickup's Avatar
Screwing them down helps to keep the heat out of the cab.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 10-04-2016, 06:00 PM   #9
CarlG
CarlG's Avatar
If you get the stainless screws, it's not really a big deal to take the floorboards out anyway.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-04-2016, 06:52 PM   #10
Bruce Adams
Bruce Adams's Avatar
Consider purchasing an Optima Battery which needs no attention for ten years or so.
Bruce Adams is offline   Reply With Quote
Old 10-04-2016, 09:12 PM   #11
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What about the connections?
Old 10-04-2016, 10:34 PM   #12
Y-Blockhead
Yeah, Well with the stainless trim rings around the shift and brake boots like on my car it is kind of a big deal. They are screwed to the floor and would have to be removed.
With the Snyder kit I mentioned above I just flip the carpet up on the drivers side and remove six screws to remove half the floor. I don't have to remove the trim rings.
Old 10-04-2016, 10:48 PM   #13
w.michael
w.michael's Avatar
At one of the French Lick National Meets, someone on the grand tour in a fordor ran off the road on a downgrade, and rolled the car over. I was not there, but videos were posted here and elsewhere. After watching the videos, I realized that even in a gentle roll-over (if there is such a thing) my floor boards would fall out and rattle around inside the car with me; and worse, my battery, which was also not tied down, would dangle from its cables and beat me up with every swing. Now I know my Model A is not really the safest thing to be driving in a collision, but I think I should make efforts to keep it at least as safe as originally designed. The French Lick video prompted me to secure the battery and the floorboards for the first time since 1964.
I believe that securing the floorboards and the battery gives you a greater margin of safety, however slight.
W. Michael
w.michael is offline   Reply With Quote
Old 10-05-2016, 12:56 PM   #14
luchoster
luchoster's Avatar
I'm looking to get a carpet like that one. Any change you can tell me where you got it?
Thanks!
luchoster is offline   Reply With Quote
Old 10-05-2016, 02:37 PM   #15
Y-Blockhead
Thanks!
It's made by Cartouche'. I think I got it from Bratton's but check first.
