Old 09-28-2016, 03:59 PM   #1
Afordman31
Afordman31's Avatar
Default Just a thought
I bead blasted a Zenith and a Holley carb, cleaned out the ports and installed new jets etc. I then painted them with fuel resistant paint.
My thoughts for putting them on the shelf and not letting the flange and inside the choke area rust .....as I didn't paint these areas.
Wondering if anyone ever tried vacuum sealing to keep out the air?
Afordman31 is offline   Reply With Quote
Old 09-28-2016, 04:55 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Just a thought
Oil the bare metal them stick them in a clear baggy.
Don't store parts in cardboard boxes unless you like to give homes to mice.
Old 09-28-2016, 06:56 PM   #3
SeaSlugs
SeaSlugs's Avatar
Agreed, try gun oil, its meant to prevent rust and cling. Treat it like a firearm. That birchwood casedy does make a spraycan called "Barricade" thats meant for long term storage.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-28-2016, 07:05 PM   #4
C26Pinelake
Gun oil is a great idea. I have used it for years. Wayne
C26Pinelake is offline   Reply With Quote
Old 09-29-2016, 09:45 AM   #5
Mikeinnj
Mikeinnj's Avatar
Put it in a plastic bag and shoot a little WD40 in the bag to prevent rust,and seal it up.
Mikeinnj is offline   Reply With Quote
Old 09-29-2016, 10:24 AM   #6
SeaSlugs
SeaSlugs's Avatar
I'm not a big fan of wd40. Works great for a short time then gets gummy. Which yea will prevent rust but if you vet some stuck to a jet or gums up the float valve then you have to take it all apart again...
Old 09-29-2016, 12:16 PM   #7
Big hammer
Electronics are shipped with a desiccant to keep moisture at bay! It can be used over by baking it in a oven. Put it in a plastic bag with your parts and sleep well at night!
Old 09-29-2016, 12:35 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
X2
If you don't have any desiccant left over from your electronic purchase you can buy it for not too much. https://www.amazon.com/s/ref=nb_sb_n...ords=desiccant
Old 09-29-2016, 02:17 PM   #9
SeaSlugs
SeaSlugs's Avatar
Originally Posted by Y-Blockhead View Post
X2
Shoes also typically come with little sugar packet sized ones - ask at your local shoe store they may have a few layin around.
Old 09-29-2016, 03:43 PM   #10
Jeff/Illinois
Jeff/Illinois's Avatar
I'd go w/ SeaSlugs coat the unpainted surfaces with Hoppe's Gun Oil smells good too
And, sealed in a bag with either dessicant OR the oiled paper John Deere uses to package their finely machined parts to protect them. And keep in a dry place not a wet basement or concrete block garage.
Old 09-29-2016, 11:07 PM   #11
Benson
I would use the Desiccant or oiled paper and remove the gasoline from carb before storing it.
1. Remove bolt and split the carb in half.
2. Blow air to remove gas from the passages, main and cap jets so that it does not turn to goo and plug passages and jets.
Note: Do not try to save time by leaving carb assembled and blowing air in the bowl vent on engine side of carb.
If this is done the air pressure will collapse the brass float and ruin it!
Old 09-30-2016, 12:43 PM   #12
Afordman31
Afordman31's Avatar
Originally Posted by tbirdtbird View Post
maybe test them on your motor before sealing them up?
Tbirdbird
Thank you for the comeback about testing them on a motor, which I did and then separated the upper and lower halfs and used air to blow out the jets etc.
Enclosed is a picture of my motor running stand. Thanks
