One more shot
Never seen a chain drive before.
Bob |
Did you notice the rear axle?
Yep, truck hubs and axle's like we used to run on stock cars back in the 50's.
Wow, I really like that! Thanks for posting the pics.
Still smokin tires and cigars |
It's a GMC 3-71, the easiest to adapt to a flathead 4 barrel manifold because it only has one discharge outlet. 4-71 and 6-71 have two outlets.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
#9 | |
![]() Quote:
Now this is a big blower, and this car does actually run. ![]() .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV. ![]() |
That's quite impressive getting a blower drive and a fan in that length hood. It's tight but it's in. Yet see many A V8's with cut firewalls.
Adiloe, Thanks for sharing, got any pics of the other side of the engine? Like to see how he's done what he did, there something happening on the generator mount are of the intake. Martin. |
Tight is right. In photo #2 it looks like the guy may have moved the radiator forward, just a bit, to get the room he needed so as not to hack the firewall.
I found this photo on the Inter web. An obvious shot taken during construction of what appears to be this same car. A generator bracket is visible on the driver's side of the blower chain above the water pump pulley. But no generator is mounted in this photo. You can also see the truck rear axle in this photo.
#13 | |
![]() Quote:
#14 |
Silly me...I was expecting this kind of eye candy.
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
#15 |
If you look at some early pictures of cars that had blowers, some did use chain drive or a set of 6 or 8 "V" belts. When steel and Kevlar reinforced belts became available they became the norm. Cool little Model A, how does it sound when it's running?
#16 |
Have to agree Capt. The curve lines appear to be smooth and aerodynamic.
