Old 08-04-2016, 06:36 PM   #1
mrtexas
mrtexas's Avatar
Default New running boards caged nuts for 41
Finished up welding in new running board caged nuts today on one side. I replaced the rusted out bottom sheet metal with 2x3 square pipe. Should have welded in the caged nuts before I put the square pipe in but I didn't. I'll next weld in a sheet metal cover for the caged nuts to complete.
mrtexas is offline   Reply With Quote
Old 08-04-2016, 10:11 PM   #2
fordor41
fordor41's Avatar
Default Re: New running boards caged nuts for 41
Looks like the caged nuts are on bottom of the rocker box. Mine were inside. Running board probably will not pull up flush to the boxes unless I'm missing something.
fordor41 is offline   Reply With Quote
Old 08-04-2016, 10:19 PM   #3
mrtexas
mrtexas's Avatar
I will cover the caged boxes with sheet metal so they will then be inside.
Old 08-05-2016, 06:54 PM   #4
mrtexas
mrtexas's Avatar
ttt
