Old 04-16-2019, 03:20 PM   #1
mrtexas
mrtexas's Avatar
Default 41 headlight wires
Are the 41 headlight wires supposed to be attached anywhere or just left dangling?
https://flic.kr/p/2fyqrdk
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 04-17-2019, 10:45 PM   #2
fordor41
fordor41's Avatar
Default Re: 41 headlight wires
Mine originally ran inside the crossmember in front, the small one that the "V" shaped mount for the front fenders bolts to. Don't remember how they were held in but that was 25 yrs ago!
fordor41 is offline   Reply With Quote
Old 04-18-2019, 02:25 PM   #3
drolston
drolston's Avatar
In my '41 the wires from the headlight and parking light to the fender well are not supported. The wire harness has been replaced, but I see no way the original wires could be secured in that area. As you can see from the photo, my headlight wires have a split plastic shield for protection.
Old 04-18-2019, 09:38 PM   #4
fordor41
fordor41's Avatar
Sorry, I thought you meant left side to right side.
Old 04-20-2019, 02:40 AM   #5
fortyonerag
fortyonerag's Avatar
My headlight cables are not supported, but are sheathed for protection within the wheel well.
fortyonerag is offline   Reply With Quote
Old 04-20-2019, 11:41 AM   #6
supereal
supereal's Avatar
Some replacement wire looms include a ground wire, as most old vehicles no longe have a reliable ground thru the body or frame, and should be supported at the ends. We use good quality "zip" ties for attachment.
supereal is offline   Reply With Quote
