Old 07-14-2016, 01:59 PM   #1
corvette8n
corvette8n's Avatar
Default My $5.00 6 volt USB charging solution
I bought a duel USB motorcycle charger on eBay for 3.85 and a lighted USB cable in the dollar store, wired it up positive to pos and negative to neg on 6 volts, it works like a charm. The thing is all plastic, so you won't have to worry about a stray ground. I like the lighted USB cable so I can see at at glance that I have power.
Old 07-14-2016, 02:57 PM   #2
Merc Cruzer
Merc Cruzer's Avatar
Default Re: My $5.00 6 volt USB charging solution
What a great idea. Thanks that solved a problem for mounting since the housing is plastic it can be mounted anywhere. Since it is nothing more than voltage reducer, I wondered if 6 volt would be a sufficient supply and eventually it is.
Merc Cruzer is offline   Reply With Quote
Old 07-14-2016, 09:45 PM   #3
Old Henry
Old Henry's Avatar
I did the same. Charged my mp3 player fine but not my cell phone.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 07-14-2016, 09:50 PM   #4
tubman
tubman's Avatar
Professor, Did you by any chance check the voltage output from the unit? (To the OP; same question.) All in all, I like the idea and plan on using it.
Old 07-15-2016, 10:53 AM   #5
corvette8n
corvette8n's Avatar
So far I have only used it with my phone, I have a tablet and USB powered GPS I still need to try.
Old 07-16-2016, 05:46 PM   #6
Merc Cruzer
Not sure when cigar/cigarette lighters first came in cars. I have a 53' Merc so by then they did have one. The adapter will not work since the polarity is reversed, the best idea was the original one. I will mount the charger in my ash tray, so it will be out of sight. This works well in my wife's 70' Cougar though.
Old 07-16-2016, 05:57 PM   #7
JSeery
JSeery's Avatar
On the wiring diagrams 33 is the first year I see a Cig Lighter on. The 32 diagram does not show one, but I have no idea if they were added later in the production year.
Old 07-16-2016, 07:12 PM   #8
DavidG
DavidG's Avatar
'32 deluxe coupes (3 windows) had a cigar lighter as standard equipment from Job #1.
DavidG is online now   Reply With Quote
Old 07-16-2016, 07:46 PM   #9
VeryTangled
VeryTangled's Avatar
Smile Re: My $5.00 6 volt USB charging solution
DING. Pay the man! Priceless information.
-Jeff H
Old 07-30-2016, 10:20 PM   #10
Merc Cruzer
I bought this one and decided to install it in the ashtray. (I wasn't using the ash tray any way since I gave up smoking when cigarettes went from a quarter to 35 cents from a machine). I had another ash tray in the extra dash that I have hanging on the wall. First I drilled a hole in the bottom and put a rubber grommet in it to make sure the metal wouldn't rub and cut the wire and create a short. The best thing about these USB units, is that they are all plastic so no grounding issues. I took the plastic rectangle that came with the unit (one of the reasons I bought this USB plug) and cut it down so it fits directly in the top of the ash tray. I remembered that the "+" side of the plug goes to ground and the "-" side of the plug goes to the hot lead, controlled by the ignition switch (mine is still 6 volt pos ground in the 53' Merc). It works great and is not noticeable when not in use. And in the event the next owner (once they pry the steering wheel from my cold dead hands) wants to go back to original, all they have to do is disconnect the two wires and insert the other ashtray.
http://www.ebay.com/itm/12V-DC-3-1A-...QAAOSwv0tVCkYN
Old 07-31-2016, 01:12 AM   #11
ford38v8
ford38v8's Avatar
For those who may be curious, Henry Ford was down on cigarettes in a big way, and would not have a cigarette lighter in his Fords. Henry Ford had cigar lighters in his Fords. This is truth, not a joke. Henry apparently justified it to himself by reasoning that cigar smokers didn't inhale.
Alan
Old 08-01-2016, 11:50 AM   #12
Bruce Lancaster
Yep, cigar lighters only! Light a cigarette with one and Bennett will send someone to have a "talk" with you!
More history: There was an accessory cigar lighter for Model A's at least by '29. It was accessory only, not factory installed (unless maybe in the Town Car, a very special oddball?). In 1932 it was installed only in the deluxe coupe as noted above, but the Service Bulletins contained instructions for installing that lighter in other bodies by drilling out the center dash panel screw.
Remember, cigars only!
"..cigar smokers didn't inhale." And neither did anyone else within 50 feet.
Old 08-01-2016, 02:39 PM   #13
PeteVS
PeteVS's Avatar
Gee, I wonder if you could mount the Model A accessory one by drilling a hole in the dash for it.
Old 08-01-2016, 05:53 PM   #14
Merc Cruzer
Looks like they were to the left of the steering column brace, or was that an aftermarket unit?
https://www.fordbarn.com/forum/showthread.php?t=201687
