Old 06-12-2016, 12:32 PM   #1
GOSFAST
GOSFAST's Avatar
Default Cam Dimensions on OEM Blanks
I know there are some guy's up here in the cam business regrinding cams, using the original cores, in order to gain on lift.
I'm trying to get a measurement on the amount removed from the original base??
Also the actual height from the journal to the heel of the lobe on one of the regrinds? I could see a variation here but it should be minimal.
Thanks, Gary in N.Y.
P.S. This is one area I cannot check over here, have no regrind's on the shelf. I have some new, Comp's and Isky's, and know the number from these, but not on the regrinds!
GOSFAST is offline   Reply With Quote
Old 06-12-2016, 01:32 PM   #2
Ole Don
Ole Don's Avatar
Default Re: Cam Dimensions on OEM Blanks
I measured a nice stock cam base and one reground to pretty wild. The difference was .221.
Ole Don is offline   Reply With Quote
