Old 05-27-2016, 11:55 PM   #1
Kahuna
Kahuna's Avatar
Default Engine question
What is a "Touring Engine"?
I see this in ads for cars for sale. What exactly is a touring engine?
Thanks
Jim
Kahuna is offline   Reply With Quote
Old 05-28-2016, 12:21 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Engine question
Just a generic term to usually mean a higher compression head, usually a slightly hotter cam, and maybe insert bearings.
My completely stock engine tours just fine, but sometime I'll install a higher compression head.
Old 05-28-2016, 10:09 AM   #3
JohnLaVoy
JohnLaVoy's Avatar
Tom, has it pretty well dialed in. Also larger valves on the intake to breath a little better with the hotter cam. It usually brings the horsepower up to around 80+ so you have a little easier time "touring".
JohnLaVoy is offline   Reply With Quote
Old 05-28-2016, 10:46 AM   #4
Jim Brierley
Not all "touring" engines are the same but generally means horsepower has been raised for more comfortable touring.
Old 05-28-2016, 01:33 PM   #5
captndan
captndan's Avatar
80 out of 40? WOW!
captndan is offline   Reply With Quote
Old 05-28-2016, 03:54 PM   #6
msmaron
msmaron's Avatar
To build a Model "A" Highway Touring Car, I recommend the following items to start with:
• Model A counterbalanced engine with clutch and lightened flywheel.
• Touring Grind Camshaft
• Insert Main Bearings
• NEW Insert connecting rods with bearings
• New Hi Compression Head
• Larger Intake Valves 1.730 Head Dia.
http://www.antiqueenginerebuilding.com/Ahwy.html
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-28-2016, 04:53 PM   #7
western77
western77's Avatar
Do you really get 80+ hp with higher compression head and "hotter cam". How high of compression do you need? Thanks JB
western77 is offline   Reply With Quote
Old 05-28-2016, 05:31 PM   #8
Gary WA
Gary WA's Avatar
Enough to tour!!
www.whidbeymodelaclub.com
Old 05-28-2016, 10:52 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Look here;
http://www.modelaparts.net/dynosheet...ynosheets.html
Old 05-29-2016, 02:11 AM   #10
wensum
wensum's Avatar
From all that I've read, I guess that my motor has around 80HP. It certainly charges up the steepest hills effortlessly in top gear and only needs second for very tight corners. (the body is also very light)
However it appears to lack the really low down lugging power of a standard engine, but then with a light flywheel and all the typical mods mentioned above, that's a small sacrifice for comfortable cruising at 60mph?
If you plan long distance motoring and don't want to be a slow moving hazard on the highways, then the improvements are readily justifiable.
Keith
wensum is offline   Reply With Quote
Old 05-29-2016, 10:41 AM   #11
Jim Brierley
80hp is not hard to attain. Piranio's site covers it pretty well (posted above by Mike V.). A 6:1 head and a Stromberg 97 or equivalent will really make a difference, even with a stock or B cam.
