My car is a 1930 coupe, I have bought an "Aford-able" oil filter kit and a 90 degree filter adaptor. Whilst waiting for the oil pan to drain ready for removal I thought I would fit the new valve cover, so without checking I went ahead, nice, fits a treat except the oil return pipe, to short. Looking at pics on the Barn I have the earlier pipe and cover and it states they are not interchangeable, I must be reading it wrong, or missing something because the way I see it the new valve cover shouldn`t fit ? or do I just need to get hold of the newer pipe ?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe |
Yes, the pipe location changed slightly and with that the length of pipe.
Get the different return pipe. Good luck
Getting hold of a pipe over here will be a problem, although my pipe is the old shape would it be ok to braze in a piece to extend it ?
Here`s a couple of pics of it.
Sorry the valve chest wasn`t meant to be there, that was for another post, just wanted anyone to see if there was anything out of place.
Sorry but I can't find the picture.
Thanks,I hadn`t thought of that, a good idea.............no problem with the heat ?
Why did you decide you needed an oil filter?
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Weld solder or braze a piece in or fabricate a new pipe and solder your old ends on. It can be done.
I see them on ebay quite often. Here's one for $7 if your interested. (not mine). Don't know what shipping to England would be tho. http://www.ebay.com/itm/ford-model-a...BVHqv8&vxp=mtr
Being from England, is your car right hand drive? And is it the special small engine?
I'd just buy the right pipe from Bert's or ebay. |
Tom- its lhd got the larger engine if I can find the right pipe I'll buy it but meanwhile I'll have a shot at extending mine
Y-blockhead- thanks for the link had spotted it doesn't ship to england J franklin- going to give it a go and braze in a piece 700 rpm- It will help keep the oil cleaner, maybe boost oil pressure, I'm not an engineer just listening to others, and reading thru other peoples posts and making a decision based on that, it can only help not harm............... Thanks for all input.
#13 |
#14 |
Dennis, I asked because I have also considered a filter, for the same reasons you state. In the end, though, I decided the benefit was minimal and the cost was too great. I drive my cars all the time, all stock, and just make certain I change my oil every 500 miles.
#15 |
700rpm - Yes, I know, I weighed up the cost, especially as I have import etc., when the old girl is finally done it will be my only transport, well her indoors has a car but I want to use the `a`, it`s a hobby if you like.
I intend to keep it stock, it will never be a show car, to many little changes i.e. red engine and wheels, incorrect bolts - I found removing the engine pans a pain in the butt so I fitted riv-nuts easy as you like now and other little things but unless you know your `A`s` the mods aren`t to obvious
#16 |
Dennis, no problem w/heat, here's the pic:
Still looking for a correct tube.
#17 |
Thanks, it doesn`t look bad, in my case it would be hidden by the oil filter, i have a piece of steel tubing on order, didn`t have any the correct size, going to have a go at brazing a piece in, got a bit of vinyl as backup in case it goes wrong
![]() That`ll be two of us looking........................
